EvLer
- 454
Hi everyone,
I have this problem and just need someone to check or correct:
f(t) = -4e^{-3|t|}(u(t + 3) - u(t-1))
where u(t) is step function: u(t) = 1 for t >= 1 and 0 elsewhere;
so, i guess I need to break abs value into 2 cases and have 2 different equations? anyway, here's what I have if someone would be so kind and check my work (at first I applied linearity property and distributed -4e^{-3|t|}:
1. for t > 0:
L[f(t)] = \frac{-4}{s+3} + \frac{4e^{-(s+3)}}{s+3}
2. for t < 0:
L[f(t)] = \frac{-4}{s-3} + \frac{4e^{-(s-3)}}{s-3}
thanks in advance!
ps: i guess one thing I should explain is that by definition of unilateral laplace transform, even though first part of signal starts at -3 we do not consider it, what we are doing is one-sided Laplace transform, so I started integrating from 0- the first part of the expression.
edit: to (hopefully) increase chances that someone looks at this here's the Lapl. trnsf. that are relevant:
L[u(t-k)] = \frac{e^{-sk}}{s}
L[e^{at}f(t)] = F(s-a)
but you probably know this anyway :shy:
1. for t > 0:
2. for t < 0:
thanks in advance!
