LaPlace Transformations to Solve Ordinary Differential Equations
4 replies · 4K views · last reply
Mike86
Consider the initial value problem:
x'' + 2x' + 5x = δ(t - 1); with: x(0) = 0 and x'(0) = 0.
Using Laplace transforms, solve the initial value problem for x(t).
L[x''] = (s^2)*L[x] - s*x(0) - x'(0)
L[x'] = s*L[x] - x(0)
L[δ(t - 1)] = e^(-s)
Using the above known Laplace Transformations and the initial conditions I have gotten:
L[x''] + 2L[x'] + 5[x] = L[δ(t - 1)]
(s^2)*L[x] - s*x(0) - x'(0) + 2 (s*L[x] - x[0]) + 5 (L[x]) = e^(-s)
(s^2)*L[x] + 2s*L[x] + 5*L[x] = e^(-s)
(s^2 + 2s + 5)*L[x] = e^(-s)
L[x] = e^(-s) / (s^2 + 2s + 5)
From here I am not sure what Laplace Transformation to use to get the answer x. I can't really factorize (s^2 + 2s +5) because I would have to use the quadratic formula and I would get solutions with imaginary parts (from where I have no idea where to go as far as Laplace transformations are concerned).
I'm not sure if I made a mistake in the lead up (I can't see where) or there is a way to continue from here with the quadratic formula. Any advice with be immensely appreciated. Thanks!
Use the partial fractions technique in
[tex]\mathcal{L} = \frac{e^{-s}}{(s^2 + 2s + 5)}[/tex]
Then, in order to find x in your new expression, you'll have to apply the Inverse Laplace Transform [tex]\mathcal{L}^{-1}[/tex].
By the way, do you remember how to use partial fractions? And do you understand how the Inverse Laplace Transform works?
Write the Laplace transform in the form
[tex]X(s) = \frac{e^{-(s+a)}e^a}{(s+a)^2+b^2}[/tex]
for the appropriate a and b. Then you should be able to use the properties of the Laplace transform and your table to get back to the time domain.
Thanks for the replies! :)
I have obtained values of: a = 1 and b=2.
Only problem is I can't make the connection between the properties of the Laplace Transformations and my tables. I've been playing around and looking for an hour or so but I've been stumped!
Sorry, I made a mistake. You want it to look like
[tex]X(s) = \frac{e^{-s}}{b} \left[\frac{b}{(s+a)^2+b^2}\right][/tex]
(It's just a slight algebraic rewrite; your a and b don't change.) Look at the frequency- and time-shifting properties of the transform.
