Laplace transforms for transient analysis
33 replies · 7K views
agata78 said:
I used this website to educate myself a bit more then i remembered from school www.mash.dept.shef.ac.uk/Resources/web-partialfractions.pdf
But does it matter which way i used to calculate A and B.
i(t)= 20e 1 + (-20) -2t
But what next?
Your transformation of the Laplace terms does not look right! You have found the that in the Laplace domain:
$$I(s) = \frac{20}{s} - \frac{20}{s + 2}$$
Find the forms of those two terms in your Laplace Transform tables and convert them to time domain terms. The result should look familiar!
agata78 said:
the only way it could be is:
20-20e(-2t)
Right. Technically each term is multiplied by a unit step function to indicate the the voltage is "switched on" at time t = 0. Mathematically it means that this solution applies only for t ≥ 0.
So, writing it in proper form for a function:
[STRIKE]I(t)[/STRIKE]Vc(t) = 20-20e(-2t) = 20(1 - e(-2t))
[STRIKE]
Now you can move on to finding Vc(t). Use the same methods.[/STRIKE]
EDIT: Sorry about that. I misremembered where we were at in the problem sequence! I think you're done with this one!
Yes i was actually trying to ask you why would i have to calculate it again.
Hurrayyyyy!
Thank you so much for help all the way! One to go!
