Lasers, photo-electric effects and ionization of atoms
The discussion revolves around the principles of laser operation, particularly in relation to the photoelectric effect, the mechanisms by which lasers cut materials, and the interaction of light with different materials, including reflections and absorption spectra. It encompasses theoretical and conceptual aspects of lasers, photoelectric effects, and material properties.
  • Some participants question whether the photoelectric effect is the only principle underlying laser operation and whether lasers cut materials by ionizing atoms.
  • Others argue that lasers primarily cut metals by heating them to their melting point through energy transfer, rather than ionization.
  • A participant suggests that if lasers heat metals by exciting electrons, it raises questions about why mirrors can reflect laser beams without similar excitation occurring.
  • Discussion includes the importance of wavelength and absorption spectra in determining how materials interact with laser light, with some noting that lasers are tuned to specific wavelengths for maximum absorption.
  • There is speculation about the absorption characteristics of gases like oxygen and nitrogen, with a participant suggesting that solid oxygen might not be cut by lasers due to low absorption.
  • Participants express uncertainty about the mechanisms of reflection, with references to quantum mechanical explanations and the role of absorption and emission of photons.
  • Questions arise about the behavior of light when transitioning between different media, specifically regarding the nature of refraction and diffusion.
  • Some participants clarify that high-power laser systems utilize dielectric mirrors, which differ from traditional metalized mirrors.
Participants express a range of views on how lasers operate and the mechanisms involved in cutting materials. There is no consensus on the role of the photoelectric effect or the specifics of light interaction with materials, indicating ongoing debate and uncertainty.
Participants acknowledge limitations in their understanding of certain phenomena, such as the specifics of reflection and the absorption spectra of different materials. There are references to unresolved questions about the behavior of light in various contexts.
This discussion may be of interest to individuals exploring the principles of laser technology, light-matter interactions, and the underlying physics of absorption and reflection in different materials.
Nerd
I get the photo-electric effect but I am just wandering, is that the only principal on which lasers function? I mean do lasers "cut" materials by ionizing the atoms?
Lasers typically cut metals by heating them up to melting point. When applied, they typically vapourize metal at just that region, and heat is dissipated very fast which is why they're used - to give very decent cuts where CNC milling wouldn't be the greatest option.
No need for ionisation, just pure energy transfer. Also, I don't think the photoelectric effect is the most appropriate way to describe light interacting with solids. I don't know what is though, but plenty on here do.
What you say makes sense, however if lasers did cut metal by heating it to melting point, I would think that this happens by exciting the electrons in the metal, which would lead to more kinetic energy and thus increase heat. If this is true than why do mirrors reflect lasers beams, afterall the same that happens to the metal's atoms should happen to the mirror's atoms?
It depends vastly on the wavelength. Speaking from a generalised point of view, every material has a characteristic absorption spectrum - for each wavelength of electromagnetic radiation, we can say it'll absorb x% of it. For metal-cutting, you would use a laser tuned to maximum absorption (and hence maximum heating) which I think is in the infrared range. It doesn't matter if it's transparent to us or reflective to us as long as absorption takes place in whatever range of wavelengths that is viable.
I have no idea why reflection occurs to tell you the truth. It doesn't seem to be actually explained anywhere (at least pre-undergraduate level).
Then we can assume that air (oxygen, nitrogen ect.) have practically no absorption, since the whole electro-magnetic spectrum can travel through air. This means that it would be impossible to cut solid oxygen with any type of laser, right? Do you know if a mirror can reflect X-rays?
Fact is high power laser systems do not use metalized mirrors. They use what is called a dielectric mirror, it consists of multiple layers of a dielectric material, the thickness of a layer is determined by the wavelength of the laser and the angle of reflection needed. These mirrors are transparent to all but the wavelength designed for.
It depends on the absorption spectrum of oxygen. I would imagine that solid oxygen has a slightly different spectrum from gaseous oxygen (because these things mostly come from the bulk properties of a material and not the individual atoms).
As for x-ray reflecting mirrors, again, I have no idea. Considering that mirrors are simply just a very convenient way to execute a quantum mechanical trick, then surely an x-ray reflector should be possible. In fact there is research going on into antennas (the sort that you use to pick up TV and radio) being used to pick up and transmit visible light signals. This of course is not the same thing as an x-ray reflector but EM waves are just that, there is nothing special about any particular wavelength or range of wavelengths, other than the arbitrary significance we associate with them.
As I said, I honestly have zero idea as to why reflection occurs! Here's what Wikipedia says on the matter:
All interactions between photons and matter are described as series of absorptions and emissions of photons. When an arriving photon strikes a single molecule at the surface of a material, is absorbed and almost immediately reemitted, the ‘new’ photon may be emitted in any direction, thus causing diffuse reflection.[citation needed]
Specular reflection (following Hero's equi-angular reflection law) is a quantum mechanical effect explained as the sum of the most likely paths the photons can take. Light–matter interaction is a topic in quantum electrodynamics, and is described in detail by Richard Feynman in his book QED: The Strange Theory of Light and Matter.
The energy of the incoming photon may match the energy required to change the molecule from one state to another, causing a transition in kinetic, rotational, electronic or vibrational energy. When this occurs, the photon may not be reemitted or alternatively may be reemitted with a loss of energy. These effects are known as Raman, Brillouin and Compton scattering.
In fact I did read the book cited and came out knowing less :smile:.Oh, I might add - air has very little absorption mostly because it's far less dense than a solid. In my early education, that corresponds to a very very low decay/absorption constant (look up the exponential law of absorption). Whereas, with a solid there is a much higher chance of absorption.
Thank you.
I have another question though. Diffusion occurs when a wave enters a optical denser material or visa versa, for instance, a light wave moving from air into water will change direction. Does the light wave's direction change at the first water molecule that reemits it or does it happen deeper into the water, and why doesn't the direction of the wave change again as it is reemited from the second molecule?
I think he was talking about mirrors outside lasers :). But hey, I didn't actually know that snippet.
Nerd said:
Thank you.
That's refraction, not diffusion. I think it's covered in one of the FAQ threads here. Other than that, I honestly have no idea (I'm actually trying to find out why myself).
So was I.
http://en.wikipedia.org/wiki/Dielectric_mirror"
Nerd said:
Thank you.
Sorry, I meant refraction. It's a translation error on my part.
The whole electromagnetic spectrum is really really large (really infinite)
At any rate, both molecular nitrogen N2 and molecular oxygen O2 absorb very strongly in the ultraviolet. Almost 100% of the incident light from the sun below 190 nm is absorbed. Modtran is a wonderful program for simulating transmittance through the atmosphere
google Modtran and Hitran
x-rays can be reflected at large (close to 90 degrees) angles of incidence. This principle has been used by astronomers to make x-ray telescopes.
See http://en.wikipedia.org/wiki/Wolter_telescope
  • · Replies 0 ·
  • · Replies 18 ·
