Undergrad How Does the Successive Minima of a Lattice Compare to Basis Vectors?
Peter_Newman
Hello,
I've been thinking a bit about the definition of the ##i##-th successive minima of a lattice (denoted with ##\lambda_i(\Lambda)##), and I would argue that the ##i##-th successive minimum is at most as large as the largest lattice basis vector ##b_i##.
More formally:
##\lambda_i(\Lambda) \leq \max_{i} ||b_i||##
So purely intuitively I would say that makes sense, but is there any way to show this?
Now you could also come up with the idea to claim that the following holds:
##\lambda_i(\Lambda) \leq ||b_i||##
Is there a way to prove this here, I can't find one at the moment unfortunately, while I'm also not sure if this is even possible...
I would be very grateful for any helpful comments!
What is your definition of the successive minima? The one I know makes this really obvious.
  • Skeptical
Likes Peter_Newman
There are different definitions. I would suggest this one:
## \lambda_i(\Lambda) = inf\left\{r > 0 | \text{ Linear independent lattice vectors } v_1,...,v_i \text{ with } ||v_j|| \leq r \text{ for } j = 1,2,...,i\right\} \quad \text{ for } i = 1,...,n##
Which one do you have?
That's the one I know.So if you pick ##i## basis vectors, they are independent. That's an example of a set of vectors used in the definition of ##\lambda_i## What does that say about the length of the longest vector compared to ##\lambda_i##?
By definition I would say that ##\lambda_i## has to be less or equal to that longest vector. Is this ok? Basis vector alone makes no shortest vector, but it could...
Yeah, that's the whole proof
Likes Peter_Newman
Thanks, so this proofs ##\lambda_i(\Lambda) \leq \max_{i} ||b_i||##. This also makes sense from the definition!
Then I have another question about this ##\lambda_i(\Lambda) \leq ||b_i||##, how would one prove or argue this. I'm bothered by the ##i## in the vector (##b_i##) here, because that implies some sort of "sorting" of the vectors...
You have bad notation with that max, having the index be the same as the left hand side. I would say given a basis ##b_1,...,b_n## of the lattice, for ##1\leq i \leq n##, ##\lambda_i \leq \max_{j} ||b_j||##. In fact, we even know ##\lambda_i \leq \max_{j\leq i} ||b_j||##. (Or same for the max over any ##i## of the basis vectors) In the case where the basis is ordered such that ##||b_1|| \leq ||b_2|| \leq ... \leq ||b_n||##, this implies ##\lambda_i \leq ||b_i||##
Likes Peter_Newman
Yes, that' s true, I agree!
That's a good way of putting it! Thank you!
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 16 ·
11K
