Laurent expansion of ##ze^{1/z}##
The original poster is seeking assistance with finding a Laurent series for the function ##f(z)=ze^{1/z}## centered at ##z=1##. They express concern over the complexity of their incomplete solution and the urgency of their exam preparation.
  • Some participants discuss the possibility of using derivatives and algebraic manipulation to find a suitable expansion, while others question the validity of certain derivative relationships. There is mention of exploring Taylor series as an alternative approach.
The discussion is ongoing, with various participants exploring different methods and questioning assumptions. Some have suggested alternative approaches, while others express frustration over the complexity of the problem and the lack of a straightforward solution.
Participants note that the function is entire and does not have singularities at ##z=1##, which may influence the method of expansion. There is also a sense of uncertainty regarding the expectations of the exam and the nature of the problem itself.
Terrell
Find a Laurent series of ##f(z)=ze^{1/z}## in powers of ##z-1##. Is there an easier way to go about this as this is not a typical expansion I see on textbooks. It seems that my incomplete solution is too complicated. Please help, exam is in two days and I am working on past exams. Worked out solutions are welcome, also. P.S. it may seem like I'm cramming, but it's not under my control - :cry:
Since ##f(z)## is entire, then it is analytic in any annular domain. So let's pick the domain ##\frac{1}{2} \lt \vert z-1\vert \lt 3##. By Laurent's theorem the coefficients
\begin{align}a_k=\frac{1}{2\pi i}\int_{c}\frac{(1+e^{it})e^{\frac{1}{1+e^{it}}}}{e^{it\cdot k}}\end{align}
where ##C## is the contour ##z(t)=1+e^{it}## and hence, ##dz=ie^{it}dt##. Note that the contour ##C## is within our selected annular domain as it should be according to the theorem.
I think I see a trick to this one: ## f'(z)=(z-1)f(z) ##, and if you do the algebra, and I think you can show ## f^n(z)=(z-1)f^{n-1}+(n-1) f^{n-2}(z) ##. ## \\ ##That would make it suitable for a Taylor expansion about ## z=1 ##. Note that ##f^n(1)=(n-1)f^{n-2}(1) ##. ## \\ ## It looks like the odd number derivatives are zero and the even ones are ## (n-1)! =(n-1)(n-3)(n-5)...(1) ##. (I think I have the correct definition of n!=Edit: yes I googled it: see http://mathworld.wolfram.com/DoubleFactorial.html) And hopefully I don't get dinged for supplying a solution to this, because other than this approach, I wouldn't know what to do with this one. :wink:
Charles Link said:
f′(z)=(z−1)f(z)
I don't see why this is true. I got \begin{align}f'(z)=e^{1/z}-\frac{e^{1/z}}{z}\end{align}
But ##(z-1)f(z)=(z-1)ze^{1/z}=z^2e^{1/z}-ze^{1/z}##
I made an algebraic error here: ## f'(z)=\frac{(z-1)}{z^2} f(z) ##. Oh well, back to the drawing board.
I think a similar method might still be possible: Using ## f'(z)=f(z)g(z) ## where ## g(z)=\frac{1}{z}-\frac{1}{z^2} ##, so that ## f'=fg ##, ## f''=f'g+fg' ##, etc, I think you should be able to get some kind of expression for ## f^n(z) ##.
Charles Link said:
I think a similar method might still be possible: Using f′(z)=f(z)g(z)f′(z)=f(z)g(z) f'(z)=f(z)g(z) where g(z)=1z−1z2g(z)=1z−1z2 g(z)=\frac{1}{z}-\frac{1}{z^2} , so that f′=fgf′=fg f'=fg , f′′=f′g+fg′f″=f′g+fg′ f''=f'g+fg' , etc, I think you should be able to get some kind of expression for fn(z)fn(z) f^n(z) .
Is there a standard general approach you are trying to follow? Thanks!
I am just trying to find something that works. Had I not made a simple algebraic error, the first solution that I had would have been a good one. Upon further inspection, I'm not having any luck with anything that works...
I find it hard to believe they put this on a past exam. It's suppose to be a test of understanding, not puzzles. I'll try my hand at this again later, I'm working on other problems for the moment. Thank you!
I hope the people who designed the problem didn't make the same mistake that I did in thinking there was a simple solution. It's unlikely, but certainly quite possible.:wink:
I would be outrage! These are comprehensive exams and they don't get returned to us. :mad:
@Orodruin You have much more math expertise. Does this one have a simple solution that we are missing?
Here's my short-cut way to an answer:
##f(z) = z e^\frac{1}{z}## has a singularity only at ##z=0##. Which means that it doesn't have any singularity at ##z=1##. If it doesn't have a pole at ##z=1##, that means that it can be expanded in an ordinary Taylor series, using just positive powers of ##z-1##.
Given that, I think I would just let ##z = u+1## and then our function becomes ##f(u) = (1+u) e^{\frac{1}{1+u}}##. You can find the Taylor series by just taking derivatives, rather than doing complex integrals. I guess it depends on whether the assignment is intended to give you practice at doing complex integration.
With a Taylor expansion, and taking derivatives, I was unable to succeed at getting a simple formula for the series. This only worked when I made an algebraic error that was clearly wrong. Perhaps the OP or someone else can find such a formula.
