Convert Partial Fractions & Taylor Series: Solving Complex Equations
The discussion focuses on solving complex equations using partial fractions and Taylor series. The primary method involves expanding functions into Laurent series for different regions of z, specifically for 0 < |z| < 1 and |z| > 2. The user successfully derived the series for |z| > 2 by rewriting the fractions appropriately and utilizing convergence properties. The remaining challenge is to find the series for the region 1 < |z| < 2, which can be approached using the formula for infinite geometric series.
  • Understanding of complex analysis concepts, particularly Laurent series
  • Familiarity with partial fraction decomposition
  • Knowledge of Taylor series expansion techniques
  • Basic principles of convergence in series
  • Study the derivation of Laurent series for complex functions
  • Learn about the convergence criteria for series in complex analysis
  • Explore the application of partial fractions in solving integrals
  • Investigate the use of infinite geometric series in complex function expansions
Students and professionals in mathematics, particularly those studying complex analysis, as well as educators looking for effective methods to teach series expansions and their applications in solving complex equations.
dykuma
and the solution (just to check my work)
None specifically. There seems to be many ways to solve these problems, but the one used in class seemed to be partial fractions and Taylor series.
The first step seems to be expanding this using partial fractions, giving me
Now, for 0 < |z| < 1, we expand each of the fractions in the parenthesis in powers of z.
This is the Laurent series for f (z) which is valid in the region 0 < |z| < 1. I then need to get the other two series, which the next one I should try to get is for the region |z| > 2. To get that, it is suggested that I write the two partial fractions as:
However I am not sure what to do with this. I have seen things saying I should expand these two functions, and then add them together, however this does not give me the answer for the region |z| > 2, (in fact, it just gives me the first series, but a degree higher, which makes sense).
The reason for writing
$$-\frac{1}{z-1} = -\frac 1z\left(\frac{1}{1-\frac 1z}\right)$$ and then expanding is because when ##|z|>1##, you have ##|1/z| < 1## so a series in positive powers of (1/z) will converge. If you look at the way you expanded 1/(z-2), you should see that you'll get a series of positive powers of (z/2), which won't converge for |z|>2.
Thanks! Right, I okay, I see what I did wrong there, and I was able to get the correct series solution for |z| > 2.
The only question I have left is how to get the 1< |z| < 2 series. I am not sure where to start there.
$$\frac{1}{z}\left(\frac{1}{z-2} - \frac{1}{z-1}\right)= \frac{1}{z}\left(\frac{1}{-2}\cdot\frac{1}{1-\frac{z}{2}} - \frac{1}{z}\cdot\frac{1}{1-\frac{1}{z}}\right)$$
For ##1<|z|<2##, we have, ##\left|\frac{1}{z}\right|<1## and ##\left|\frac{z}{2}\right|<1##. So you can now use the formula for infinite geometric series.
  • · Replies 16 ·
