Law of multiple proportions (need method check please)
rwooduk
Carbon first:
4.61/0.39 = 11.82 C/H
Hydrogen
0.39/4.61 = 0.08 H/C
therefore 11.82/0.08 = 139.72 ~ 140
masses of carbon that combine with hydrogen are in a 140:1 ratio
Does this look right? Or have i just done the second part?
i have no idea what I am doing
Thanks for any help.
What does this mean ? You divide C/H by H/C and get C2/H2. Is that the law of multiple proportions ?
This was just a method i followed from here:
http://chemistry.about.com/od/workedchemistryproblems/a/law-of-multiple-proportions-problem.htm
there are 57.1 g O and 42.9 g C. The mass of O per gram C is:
57.1 g O / 42.9 g C = 1.33 g O per g C
there are 72.7 g O and 27.3 g C. The mass of oxygen per gram of carbon is:
72.7 g O / 27.3 g C = 2.66 g O per g C
Dividing the mass O per g C of the second (larger value) compound:
2.66 / 1.33 = 2
Is this method not correct?
As I understand it so far for AB and AB2 there are small number ratios for the B of each compound. I am unsure how to apply this to the question.
Many thanks for the reply
Ha, in the example, there are two substances. In one of them, there is twice as much O per C as in the other. (so one can be CO4 and the other CO2, for example -- but CO and CO2 is more probable :wink:) .
You only have one substance, so I'm afraid you will need atomic weights to work towards a nice ratio.
ahh i see thanks
please could you expand on this a little?
Did the 140 I got have any relevence?
thanks again
LOMP: Law which states that when elements combine, they do so in the ratio of small whole numbers (assuming they have the same type of chemical bonds).
For two substances with different weight ratios you can divide out the atomic weights.
Molecules are formed from atoms (or other molecules) in the ratio of small numbers of constituents. The constituents are not counted in amounts of mass but in amounts of atoms (or molecules). So you have to convert the masses to number of atoms by dividing by the atomic weights.
[edit] And the 140 is C2 / H2 in kg2/kg2, for which I can't think of an interesting physical meaning :smile:
Ahh I see, yes, ok thanks very much for your help!
You're welcome. Interesting substance ! This ratio has puzzled mankind (well, the scientific community) for a while, until August Kekule dreamed up the solution !
Likes rwooduk
Yes, as said, for multiple proportions law you need two compounds. If as well as data in #1 you use that in #3 you can answer the question.
Likes rwooduk
21K
10K
