LC Circuit Maximum Charge Problem
6 replies · 18K views · last reply
reising1
In an oscillating LC circuit, L = 2.93 mH and C = 3.21 μF. At t = 0 the charge on the capacitor is zero and the current is 2.14 A. What is the maximum charge (in C) that will appear on the capacitor?
I know that for an LC Circuit, the charge q at a given time t is:
q = Q cos(wt + phi)
At t = 0, q = 0;
Thus,
0 = Q cos(phi),
which implies Q = 0.
So the maximum charge is 0.
However this is not right.
Any help please?
q = Q cos(wt + phi)
At t = 0, q = 0;
Thus,
0 = Q cos(phi),
Any help please?
The other possibility (the correct one) is that cos(phi)=0.
Try differentiating q(t) and use the other information given in the problem.
Okay, so
i = dq/dt = -wq sin(wt + phi)
Plugging in,
since w = 1 / sqrt(LC)
2.14 A = Q (-1 / sqrt(2.93 mH * 3.21 microF)) sin(phi)
However I'm not sure what phi is. In fact, I'm not quite sure specifically what phi is. I know it is the phase difference. But in this case, the phase difference between what?
Thanks so much.
The phase phi simply tells you where in the cycle you're starting.
With the information you're given, you can solve for phi. First, you know cos(phi)=0, so phi=pi/2 or -pi/2. From your equation for the current, you can figure out which of the two possibilities is the correct one.
Okay. I understand that one. Now here's the next part;
(b) At what earliest time t > 0 is the rate at which energy is stored in the capacitor greatest?
So, I know that U = q^2 / 2C
So U = (Q^2)(sin^2(wt)) / (2C)
deriving this (to find the "rate at which energy is stored"), we get
dU/dt = (Q^2)(w)(sin(wt))(cos(wt)) / C
The maximum occurs when sin(wt)cos(wt) is at a max, which is when wt = pi/4
So, wt = pi/4 implies that the time when the rate at which energy is stored in the capacitor is greatest is
t = (pi/4)(1/w)
plugging in values, I get
t = 7.61686 E-5 seconds
However, this is incorrect.
See my flaw anywhere?
Thanks!
Other than perhaps the number of significant figures, it looks right to me.
Going back to before, why is it that we know cos(phi) = 0?
