Learn How 6 is Derived in Strain Gage Bending Formula
  • Thread starter Thread starter sean882
    Bending Strain
The discussion focuses on the derivation of the constant 6 in the bending strain formula S_b = (F * L * 6) / (E * b * h). The formula is used to measure bending strain in a project involving strain gages for weights between 0 and 10 lbs with an accuracy of 0.1 lbs. The constant 6 is derived from the relationship between bending stress and strain, specifically from the moment of inertia formula I = (b * h^3) / 12 and the application of Hooke's law. The correct formulation of strain includes the squared height dimension, leading to the equation ε = (6 * F * L) / (E * b * h^2).
  • Understanding of bending strain and its measurement using strain gages
  • Familiarity with Young's Modulus (E) and its role in material science
  • Knowledge of moment of inertia calculations, specifically I = (b * h^3) / 12
  • Basic principles of Hooke's law and its application in stress-strain relationships
  • Research the derivation of bending stress and strain equations in material mechanics
  • Explore the application of strain gages in experimental mechanics
  • Study the implications of Young's Modulus in different materials
  • Investigate the effects of varying dimensions (b and h) on bending strain measurements
Mechanical engineers, materials scientists, and students involved in experimental mechanics or structural analysis will benefit from this discussion.
sean882
In strength of materials, we have to do a project using strain gages to measure a weight between 0 and 10 lbs with an accuracy of .1lbs. My group is using bending strain. We have a formula, S[tex]_{}b[/tex]=[tex]\frac{F*L*6}{E*b*h}[/tex], where F is the weight applied, L is the length, E is the Young's Modulus, b and h are base and height dimensions, respectively. We need S[tex]_{}b[/tex] to equal between 500 and 1,000. Where does the 6 come from in the formula? We have a feeling it comes from moment of inertia formulas somehow, but could you explain how it is derived? Thanks,
-Sean
My LaTeX equations aren't working right in PF. I think you can decipher the LaTeX code :-)
The stress due to bending is \sigma = \frac{Mc}{I}. The strain is given by Hooke's law: \epsilon = \frac{\sigma}[E] = \frac{Mc}{EI}. I = \frac{bh^3}{12} and c = \frac{h}{2} and M = F*L. This yields \epsilon = \frac{6FL}{Ebh^2}.
I'm pretty sure in your equation the h needs to be squared.
Thanks a bunch!
  • · Replies 30 ·
10K
29K
13K
15K
