Understanding LED Light Pipes: How They Work and Their Composition
  • Thread starter Thread starter likephysics
    Led Light Pipe
LED light pipes function similarly to fiber optic cables, utilizing total internal reflection to guide light effectively. The discussion highlights the potential for side-emitting light pipes, which can create effects like halo rings. Participants suggest exploring alternatives such as EL wire for cost-effective solutions. The conversation emphasizes the importance of understanding the design and application of light pipes for optimal results.
  • Understanding of total internal reflection in optics
  • Familiarity with LED technology and applications
  • Knowledge of light pipe design and functionality
  • Basic concepts of light diffusion and emission
  • Research side-emitting LED light pipes and their applications
  • Explore the properties and uses of EL wire in lighting design
  • Investigate the design principles of halo rings and their implementation
  • Learn about the effects of surface treatment on light distribution in light pipes
Engineers, designers, and hobbyists interested in LED lighting solutions, particularly those focused on innovative applications of light pipes and cost-effective alternatives.
likephysics
I have a basic question about light pipes -
How exactly does it work? Is it like Fiber optic cable (total internal reflection)?
or does it leak since the light pipe is fully made of glass.
http://en.wikipedia.org/wiki/Light_pipe
Berkeman,
So it does work like fiber optic.
Are you aware of any side emitting light pipe or LED?
likephysics said:
Berkeman,
What do you mean by side emitting? What exactly are you wanting to do?
Side emitting like a halo ring. Something like 5-10mm dia.
What's a halo ring? Can you post a sketch of what you want? Or use Google Images to search for what you want?
If you have something similar, you might be able to scratch up the surface. It'd be like a leaky pipe, so the light probably won't be as well-distributed. Or it might just result in a lit spot right where the light source is.
  • · Replies 23 ·
  • · Replies 16 ·
  • · Replies 24 ·
  • · Replies 27 ·
