Legendre's differential equation
4 replies · 22K views · last reply
cks
the question is in the jpg file
  • Typeset text working through Legendre's differential equation: general solution y = c1 Pn(x) + c2 Qn(x), then a derivation with n=0 leading to y = A ln[B((1+x)/(1-x))], questioning why it differs from P0(x) = 1.
\[(1-x^2)y''-2xy'+n(n+1)y=0 \]
The general solution is
\[y=c_1P_n(x)+c_2Q_n(x) \] where $n=1,2,3,...$
$P_n(x)$ is Legendre polynomials and $Q_n(x)$ is Legendre functions of the second kind
From the general solutions of Legendre polynomials, we know that
P_0(x)=1
However, we can also find the same solution by letting n=0 for the legendre's differential equation
\[(1-x^2)y''-2xy'+=0 \]
\[\frac{\,dy'}{\,dx}=\frac{2xy'}{1-x^2}\]
\[\int \frac{\,dy'}{y'}=\int \frac{2x}{1-x^2}\]
\[\ln y' = -\ln |1-x^2| + D \]
\[y'=\frac{B}{1-x^2}\]
Find y is pretty straightforward
\[y=A\ln \left[B \left(\frac{1+x}{1-x}\right)\right]\]
The Legendre differential equation is a second-order ODE, so it has two linearly independent solutions for each n. P0(x)=1 is one of the two solutions for n=0. You found the other solution.
The Legendre differential equation has singular points at [itex]\pm 1[/itex]. For a given n, one of the two solutions will be finite for all finite x, while the other solution will be singular at the singular points [itex]\pm 1[/itex]. The first set of solutions (finite for all finite x) are the Legendre polynomials. The second set are the Legendre functions of the second kind.
BTW, you obviously know LaTeX. This forum supports LaTeX. The start of your post converted to vB LaTeX:
[tex](1-x^2)y''-2xy'+n(n+1)y=0[/tex]
[tex]y=c_1P_n(x)+c_2Q_n(x)\ \text{where}\ n=1,2,3,\cdots[/tex]
The Legendre differential equation has singular points at . For a given n, one of the two solutions will be finite for all finite x, while the other solution will be singular at the singular points . The first set of solutions (finite for all finite x) are the Legendre polynomials. The second set are the Legendre functions of the second kind
y = cp(x)1 + dq(x)2 as n= 1,2,3..
i thik he give a good solution ..,
