Length Contraction in Particle Accelerators
- Level: Graduate
- Thread starter Mentallic
- Start date
6 replies · 4K views · last reply
Discussion
Mentor
- 23,906
- 11,368
Time dilation and length contraction are two parts of the same thing, so when you observe one you are also observing the other. For example, when a particle in a particle accelerator takes longer to decay because of relativistif effects, it also travels a longer distance than it "should", based on the same effect. But in the frame of the particle, it does not travel a longer distance than it should.
ImAnEngineer
- 209
- 1
I'm not an expert, but I'm quite sure length contraction follows directly from time dilation. A nice example are muons that come from the atmosphere. They have a very short lifetime, so without relativity you would assume that they would never be able to travel the, say, 10km in that time, but because of time delation it can. If you, however, look at the case from the perspective of the muon, the time is going at a 'normal' rate. The only way for the muon to reach the Earth is if the distance were smaller (i.e. length contraction).
For the muon experiment, click:
http://hyperphysics.phy-astr.gsu.edu/HBASE/Relativ/muon.html
Mentor
- 37,343
- 16,487
Yes, particle accelerators work. The bunch length is contracted as predicted. Plus russ_watters and ImAnEngineer are correct.Mentallic said:So does there exist any evidence to support the theory of length contraction?
Homework Helper
- 3,802
- 95
Yes I'm aware that mass dilation and length contraction both originated from time dilation, which in turn is a bi-product of the assumption that the speed of light is always constant from any frame of reference.
However, there is also evidence to support mass dilation without using this link between the two. Similarly, I'm just in search for any evidence to support length contraction without making it an assumption by the observation of the others.
How were they able to detect the contractions in length?
Thanks for the help everyone.
There is much evidence to support time dilation which would explain many phenomena. Following from this, in order to obey the law of conservation of energy, mass must also be affected. These are also two parts of the same thing.russ_watters said:Time dilation and length contraction are two parts of the same thing, so when you observe one you are also observing the other.
Could you please expand on thisdalespam said:Yes, particle accelerators work. The bunch length is contracted as predicted. Plus russ_watters and ImAnEngineer are correct.
Mentor
- 37,343
- 16,487
The total amount of charge in a bunch increases as the length contraction increases. Basically, because of length contraction you can squeeze in more charged particles in a single bunch than you could without length contraction. The design of the particle accelerator takes this length contraction into account, and the accelerator functions as designed.Mentallic said:Could you please expand on this![]()
Homework Helper
- 3,802
- 95
DaleSpam said:The total amount of charge in a bunch increases as the length contraction increases. Basically, because of length contraction you can squeeze in more charged particles in a single bunch than you could without length contraction. The design of the particle accelerator takes this length contraction into account, and the accelerator functions as designed.
Ahh thankyou for the explanation. I could've guessed the first evidence to be posted would have something to do with the particle accelerator
That same machine gave me the first, indesputable evidence of mass dilation too.
Undergrad
Linear Accelerator Length Contraction
- Orthoceras
- · Replies 1 ·
- Special and General Relativity
- Replies
- 1
- alexandrinushka
- · Replies 83 ·
- Replies
- 83
- QuasiParticle
- · Replies 7 ·
- Replies
- 7
Graduate
Length contraction of particles
- member 529879
- · Replies 2 ·
- Replies
- 2
- Xforce
- · Replies 4 ·
- Replies
- 4
- Michael C Fowler
- · Replies 5 ·
- Replies
- 5
- exmarine
- · Replies 11 ·
- Replies
- 11
- Mentz114
- · Replies 54 ·
- Replies
- 54
- mikiel
- · Replies 29 ·
- Replies
- 29
- tonyxon22
- · Replies 6 ·
- Replies
- 6
