Lens maker's equation used correctly?
  • Thread starter Thread starter DannyPhysika
    Lens
The discussion centers on the application of the lens maker's equation to a thick double convex lens with specific parameters: object distance of 60 cm, radii of curvature of 20 cm and 30 cm, thickness of 2 cm, and an index of refraction of 1.5. The correct image position calculated using the lens maker's equation is 39.9 cm, while an incorrect calculation yielded 40 cm. Participants emphasized the necessity of incorporating the lens thickness into the calculations, as neglecting it can lead to inaccuracies in the image position.
  • Understanding of the lens maker's equation
  • Familiarity with optical principles related to thick lenses
  • Knowledge of refraction and index of refraction concepts
  • Basic algebra for manipulating equations
  • Study the derivation and application of the lens maker's equation for thick lenses
  • Learn how to incorporate lens thickness into optical calculations
  • Explore the differences between thin lens and thick lens equations
  • Investigate practical applications of lens design in optical engineering
Students in optics, physics educators, and optical engineers seeking to deepen their understanding of lens behavior and calculations involving thick lenses.
DannyPhysika
An object is placed 60 cm from a thick double convex lens, with faces of radii of curvature 20 cm and 30 cm, with thickness of 2 cm, and index of refraction is 1.5. Find the position of the image. Ans: ( 39.9 cm)
lens maker's equation, na/object + na/image = (nb - na)(1/R1 - 1/R2)
I used this equation and got 40 cm, as opposed to 39.9. I figured it couldn't be a rounding error considering the numbers given. Am I supposed to use the 2 cm thickness somehow?
When I calculated the answer, it came out to be 40.9 cm. Strange! I used the lensmaker equation given in Wikipedia. These were my results : f= 900/37 cm, u=-60 cm (given) So, using lens formula v = 40.9cm. And yes you need to use the thickness. See the lensmaker's equation in Wikipedia!
@Danny :the equation which you are using seems to be derived from thin lens equation where you neglect thickness as it's too small compared to Radii of curvature.
