Solving Leplace Transform of y"+4y=7t with y(0)=-1, y'(0)=3
  • Thread starter Thread starter hils0005
    Transform
The discussion focuses on solving the differential equation y'' + 4y = 7t with initial conditions y(0) = -1 and y'(0) = 3 using the Laplace Transform method. The transformation yields L{y}(s^2 + 4) = (-s^2 + 3s + 7)/s, leading to the equation L{y} = (-s^2 + 3s + 7)/(s(s^2 + 4)). The user encounters difficulty in setting up partial fractions for the expression, specifically questioning the correct application of the Laplace Transform for the term 7t. The correct Laplace Transform for 7t is identified as 7/s^2, confirming the need to use n = 1 in the transformation formula.
  • Understanding of Laplace Transforms, specifically L{t^n} = n!/(s^(n+1))
  • Familiarity with solving second-order linear differential equations
  • Knowledge of partial fraction decomposition techniques
  • Basic concepts of initial value problems in differential equations
  • Study the method of partial fraction decomposition in detail
  • Learn about the properties and applications of the Laplace Transform in solving differential equations
  • Explore the Gamma function and its relation to the Laplace Transform
  • Practice solving initial value problems using Laplace Transforms with varying functions
Students and professionals in mathematics, engineering, and physics who are working with differential equations and Laplace Transforms, particularly those seeking to enhance their problem-solving skills in initial value problems.
hils0005
y"+4y=7t , y(0)=-1, y'(0)=3
L{y} + 4L{y} = 7L{t}
(s^2L{y} - sy(0) - y'(0)) + 4L{y} = 7L{t}
s^2L{y} - s(-1) - 3 + 4L{y} = 7(0!/s^(0+1))
L{y}(s^2 + 4) = 7(0!/s^(0+1)) - s + 3
= ((-s+3)s + 7)/s
=(-s^2 + 3s +7)/s
L{y}=(-s^2 + 3s + 7)/(s(s^2+4))
here is where I run into trouble, setting up the partial fractions
L{y}=-s^2 + 3s +7 = A/s + B/(s^2+4)
is that correct so far?
You should check the laplace transform for 7t.
L{t^n} = (n!)/(s^(n+1))
therefore L{t} = L{t^1} = (1!/(s^(1+1))
L{7t} should look more like 7*(1/s^2) or (7/s^2)
but its t^1, so n=0, t^0+1=t^1 right?
Its t^1, so n = 1 when you plug into the transform for t^n.
Or if you want the Laplace transform of t^n in terms of gamma function:
L\{t^n\}=\frac{\Gamma(n+1)}{s^{n+1}}
\Gamma(n+1)=n\Gamma(n)=...=n!,n \in Z^+
\Gamma(1)=1
