Let there be a PP capacitor where d increases, what happens to the charge?
  • Thread starter Thread starter Ling2
    Capacitor Charge
When a fully charged parallel plate capacitor is disconnected from a battery and the distance between its plates is increased, the charge (Q) on the capacitor remains constant. This is due to the fact that the charge has no pathway to dissipate. As the distance (d) increases, the capacitance (C) decreases, leading to an increase in the potential difference (V) across the plates, as described by the relationship Q = CV. The electric field remains unchanged because it is dependent solely on the surface charge density of the plates.
  • Understanding of parallel plate capacitors
  • Familiarity with the relationship between charge, capacitance, and voltage (Q = CV)
  • Knowledge of electric fields and their properties
  • Basic principles of work done in electric systems
  • Study the derivation of the capacitance formula for parallel plate capacitors
  • Learn about the effects of dielectric materials on capacitance
  • Explore the concept of electric field strength and its calculation
  • Investigate energy stored in capacitors and how it relates to voltage and charge
Students of physics, electrical engineers, and anyone interested in understanding the behavior of capacitors in electric circuits.
Ling2
If a fully charged parallel plate capacitor is disconnected from a battery and its plates are pulled apart to increase the distance between the plates, what is the value of charge on the capacitor?
I know the charge and the electric field will both remain the same, but I don't know why or how?
Since d increases, the capacitance C will decrease. Also since positive work is done on the system to separate the attracted plates, the potential difference also increases.
Welcome to PF Ling2,
If the capacitor is disconnected from the circuit, then the charge stored on the capacitor must remain the same, simply because that charge has nowhere to go.
The electric field remains the same, because it depends only on the surface charge density of the plates.
Another way to understand why the voltage increases: Q = CV. If Q is constant, and C goes down, then V goes up.
A third (more physical) way to understand why the voltage increases. The electric field between the plates remains the same, but the distance between them increases. Recall that for a uniform electric field it's simply true that V = E*d.
So [itex]V \propto d[/itex], which is why [itex]C \propto 1/d[/itex].
Thank you so much! Just the clarification I needed :)
  • · Replies 26 ·
