L'hopital's Rule for solving limit problem
The discussion revolves around evaluating the limit of the expression (x-1)^3/log(x) as x approaches 1, specifically using L'Hôpital's Rule. Participants are exploring the conditions under which L'Hôpital's Rule can be applied.
  • Exploratory, Assumption checking
  • The original poster attempts to apply L'Hôpital's Rule by differentiating the numerator and denominator but expresses uncertainty about the correctness of their approach. Other participants question the conditions for using L'Hôpital's Rule, particularly regarding the limits approaching zero.
The discussion is active, with participants providing differing views on the application of L'Hôpital's Rule. Some guidance has been offered regarding the necessary conditions for the rule, but there is no explicit consensus on the best approach to take.
There is a mention of the need for both the numerator and denominator to approach zero or infinity, which is a point of clarification in the discussion.
kmeado07
The question is:
Evaluate the following limit: lim(as x tends to 1) of [(x-1)^3]/(logx)
I tried using L'hopital's Rule, so i differentiated the top and bottom of the eqn and i got 3x(x-1)^2, then as x tends to 1 this would tend to 0.
I don't think this is correct though, and was wondering if anyone could give me some guide lines to maybe another rule to use to find the limit.
Thanks.
Why would you think so? It's perfectly correct, well done.
But to use l'hopital's rule, don't you need the limit, x, tending to zero?
No, you only need both the numerator and the denumerator tend to zero (or infinity) as x approaches some number a, for example one.
  • · Replies 23 ·
