Light Bulbs in Series vs. Parallel
The discussion centers on the behavior of two light bulbs, a 25W and a 100W, when connected in series to a 240V power source. When connected in series, the same current flows through both bulbs, leading to a situation where the power consumed by each bulb can exceed its rated capacity. The 100W bulb burns out due to the higher power consumption when subjected to the series configuration, as calculated using the formulas P=IV and P=I^2*R.
  • Understanding of electrical power calculations (P=IV, P=I^2*R)
  • Knowledge of series and parallel circuit configurations
  • Familiarity with light bulb wattage ratings and their implications
  • Basic concepts of resistance in electrical components
  • Calculate resistance for light bulbs in a 120V circuit
  • Learn about series and parallel circuit analysis techniques
  • Explore the effects of overloading electrical components
  • Investigate the relationship between voltage, current, and power in circuits
Electrical engineering students, hobbyists experimenting with circuits, and anyone interested in understanding the implications of connecting light bulbs in different configurations.
kimberlyann9
You have two 120V light bulbs, one 25W and one 100W, that are normally connected in parallel with 120V across each. Your friend had what seemed like a good idea which was to connect them in series across a 240V power line. However, one of them burned out immediately. Which one burned out and why?
P=IV
P=I^2*R
If light bulbs are in series, the same current flows through both of them. Should I treat this like a resistor problem and calculate the resistor of the light bulbs in both cases? I'm not sure how to figure out which one burns out.
P=IV
P=I^2*R
Yes.
As you stated, first calculate the resistance for each bulb in the 120 volt circuit. The resistances of your light bulbs are fixed values. Then putting them in series with 240 volt source, you will find the total system current. From that you can determine the power consumed by each bulb. Comparing the calculated power of each bulb with it's rating will make it obvious which one would burn out.
OmCheeto said:
Yes.
Okay great, thanks for your help!
  • · Replies 19 ·
