Light hovercraft powered by electric ducted fans
  • Thread starter Thread starter artemis12
    Electric Light
10 replies · 5K views · last reply
artemis12
I'm trying to make a light hovercraft powered by electric ducted fans that will have enough thrust to lift me like 10 feet off the ground. the only problem is I HAVE NO IDEA WHAT I"M DOING. can anyone help me?
i weigh 134 pounds, and the craft will weigh around 50-80. that puts the weight without the batteries and fans at 184-214 pounds. i know i need more thrust than what the object weighs to get it to float higher, but the fans will weigh a lot also, won't they? so I'm guessing i need more than 250 pounds of thrust. Anyone know how much thrust, voltage, amps, and horsepower i need to float a 214+ pound object 10 feet off the ground?
Welcome to PF, Artemis.
You're not going to get a hovercraft 10' off of the ground no matter what you do. Huge commercial vehicles with turbine engines don't lift that far. The whole point of a hovercraft is to just skim the surface.
Hovercrafts only work because they are so close to the ground.
When you get farther away you switch from a hovercraft to a helicopter -> which requires tremendously more airflow and therefore more power.
has anyone ever made a one engine hovercraft here!?
motomax99 said:
is 45lbs too heawy for the deck of my HC?
We have nowhere near enough information to answer that question - we know nothing about your hovercraft!
sorry my dad told me that too, i have a one engine split thrust hc with a yamaha 440 snowmobile and i way about 130lbs
thats not exactly true you should check these out: http://video.google.com/videosearch?hl=en&q=hoverwing&um=1&ie=UTF-8&sa=N&tab=iv#
Very cool hybrid craft, but what gets that craft a few feet off the ground isn't the hovercraft mode, it's the ground-effect airplane mode. Danger is absolutely correct: a standard hovercraft is limited to mere inches of altitude, inherrent in the design.
Btw, moving this to the aerospace forum.
mythbusters made hovercrafts from everyday objects, maybe watch that episode
