How Is the Light Ray Equation Derived from Fermat's Principle?
The derivation of the light ray equation from Fermat's Principle is established through the variational approach, which states that light follows the path that minimizes the time of flight. The time of flight is expressed as T = (1/c) ∫ n(𝑥(𝑠)) ds, where n is the refractive index and ds is the infinitesimal arc length. By varying the path and applying integration by parts, the extremal path is shown to satisfy the equation ∇n - d/ds(n d𝑥/ds) = 0, which is the desired light ray equation. This method highlights the elegance and power of the variational principle in optics.
  • Understanding of Fermat's Principle in optics
  • Familiarity with variational calculus
  • Knowledge of refractive index and its implications in light propagation
  • Basic proficiency in calculus and differential equations
  • Study the variational principle in more depth, focusing on its applications in physics
  • Explore advanced topics in optics, such as ray tracing and wavefront analysis
  • Learn about the mathematical foundations of differential equations relevant to optics
  • Investigate the implications of refractive index variations in different media
Students and professionals in optics, physicists, and engineers involved in optical measurement techniques and experimental aerodynamics will benefit from this discussion.
mvvdsteen
For a course in Experimental Aerdynamics I have to study a section on Optical Measurement Techniques. My oral exam is coming up and there is this little thing I don't understand. It annoys me expremely. It is the ray equation. It is about light ray path in a medium with changing refractive index. I will copy what's in the lecture notes, and maybe someone will know the derivation of this formulae.
\vec{e}_r: vector towards centre of curvature
\vec{e}_s: vector in path direction
Deflection (1):
n \frac{\partial \vec{e}_s}{\partial s} = \frac{\partial n}{\partial r} \vec{e}_r
Acceleration (2):
\frac{\partial n}{\partial s} \vec{e}_s
Combining (adding (2) to both sides of (1))
\frac {\partial (n \cdot \vec{e}_s)}{\partial s}=\frac{\partial}{\partial s} (n \cdot \frac{\partial \vec{x}}{\partial s})=\nabla n
with \vec{x}=[x,y,z]^T
Can somebody help me out by giving the derivation or a link to a page that contains it?
Kind regards,
Maciej
PS: So you can't let the tex automatically span more lines?
Does somebody know anything more about this set of equations?
Hi mvvdsteen,
You can easily obtain this equation from the standard variational principle for light. This principle, called Fermat's principle, states that light will take the path which extremizes the time of flight.
Ok, so how does it work out? The time of flight is given by the integral T = \int \frac{ds}{v} , where ds is the infinitesimal arc length and v is the speed of light. You know that the speed of light in a medium of refractive index n is just v = c/n, so you rewrite the time of flight as T = \frac{1}{c} \int n(\vec{x}(s)) ds, where I have indicated the dependence on arc length s. Following the usual variational approach, we try to find which path extremizes this quantity. Consider varying the path of the light ray from \vec{x}(s) to \vec{x}(s) + \delta \vec{x}(s) with end points fixed. The first order variation in the time of flight is given by \delta T = \frac{1}{c} \int \[ \delta n ds + n \delta ds \], and note that it is important to remember that the infinitesimal arc length changes too! We can easily calculate the first term as \delta n = \nabla n \cdot \delta \vec{x}. The variation of arc length is also easy to calculate: \delta ds = \sqrt{(d\vec{x} + d \delta \vec{x})^2} - \sqrt{(d\vec{x})^2} = ds \frac{d\vec{x}}{ds} \cdot \frac{d \delta \vec{x}}{ds}, where I have kept only first order terms in \delta \vec{x}. We can now write the variation of T as \delta T = \frac{1}{c} \int [ \nabla n \cdot \delta \vec{x} + n \frac{d\vec{x}}{ds} \cdot \frac{d \delta \vec{x}}{ds} ] ds = \frac{1}{c} \int [ \nabla n - \frac{d}{ds}\left(n \frac{d\vec{x}}{ds}\right) ]\cdot \delta \vec{x} ds. The last equality there follows from an integration by parts and the fact that \delta \vec{x} vanishes at the end points. The extremal path has \delta T = 0 for arbitrary variations \delta \vec{x}. This implies that the extremal path satisfies \nabla n - \frac{d}{ds}\left(n \frac{d\vec{x}}{ds}\right) = 0, which is the desired equation.
If you haven't seen it before, the variational approach is extremely powerful and elegant. I like it a lot. Hope this helps.
