Light refraction problem in water & air
The problem involves calculating the length of the shadow cast by a vertical pole in a swimming pool when sunlight strikes at a specific angle. The context includes concepts of light refraction between air and water, as well as geometric relationships related to angles and lengths.
  • Participants discuss the application of trigonometric functions to determine the lengths involved, questioning the correctness of angle assignments and the relationships between the angles and lengths of the shadow.
Some participants have offered clarifications regarding the angles used in calculations, and there is an ongoing exploration of the correct geometric relationships. The discussion reflects a mix of attempts to correct misunderstandings and validate approaches without reaching a definitive conclusion.
There is a mention of a figure that is referenced but not provided in the thread, which may affect the clarity of the problem setup. Additionally, the participants are navigating through potential errors in angle interpretation and shadow length calculations.
MrMoose
In the figure attached, a 2.00m long vertical pole extends from the bottom of a swimming pool to a point 50.0cm above the water. Sunlight is incident at 55.0° above the horizon. What is the length of the shadow of the pole on the level bottom of the pool?
See figure attached for my drawing.
n1 = 1 for air
n2 = 1.33 for water
sin(θ2) = (n1/n2)*sin(θ1)
Since N2 > N1, we know that the beam bends towards the normal.
θ1 = 90° - 55° = 35°
θ2 = arcsin[(1/1.33)*sin(35°)) = 25.55°
From here, it's geometry:
Tan(55°) = X1 / 50cm
X1 = 0.71m
Tan(25.55°) = X2/1.5m
X2 = 0.71m
X = X1 + X2 = 1.43m
According to the back of the book, this is not correct. Where am I going wrong? This seems like a really straight forward problem. Thanks in advance, MrMoose
This is not the correct angle.
Hi mfb, please elaborate, I still don't see the error. Tangent of the angle is equal to the length of the opposite side over the length of the adjacent side.
The opposite side of your 55°-angle is the .5m of the pole, and not the length of the shadow. If you want to calculate this part in the same way as you did the part under water, you need the corresponding angle (relative to the vertical, 35°).
Oh wow, that was a silly mistake. So...
Tan(55°) = 50cm/X1
X1 = 0.35m
And X = X1 + X2 = 1.07m, which is the correct answer.
Thanks so much for your help.
9K
30K
10K
