LIGO and light speed constancy
118 replies · 11K views
DanMP said:
Why we detect a stretch?
In general relativity the metric determines distanced and time intervals between events. For a GW the metric is time dependent so the distance between points is time dependent. The length between mirrors is changing as the wave passes. This distance change doesn't depend on ones choice of coordinates. One may, for example, choose coordinates in which the mirror locations are constant and the distance between mirrors is changing because the metric is time dependent. Now, because the distance between mirrors is changing the number of wavelengths between mirrors is changing. This is what is measured.
DanMP said:
If the gravity wave propagates with the same speed as light, it should affect (move) the mirror at the other end just before the light from the "displaced" source arrives there, so the distance between the light source and the mirror would not be stretched. Why we detect a stretch?
Gravitational waves are transverse. The stretch happens along the tunnel if the wave is propagating across the tunnel.
The gravity wave is propagating in a different direction from the light beams traveling down the arms. In the simplest case, the detector is perfectly transverse to the wave, so a given wave front arrives at all points on the detector (i.e., everywhere in both arms) simultaneously. In more complicated cases, the detector's plane is not perfectly transverse, but if you work out the math, that just means the amplitude of the signal detected gets reduced.
I didn't know that "gravitational waves are transverse". I believed (and still do) that GWs are longitudinal ...
The latest detection, https://dcc.ligo.org/public/0145/P170814/010/GW170814.pdf "allowed us to probe the polarization content of the signal for the first time; we find that the data strongly favor pure tensor polarization of gravitational waves, over pure scalar or pure vector polarizations". What does this means? It implies, by any chance, longitudinal oscillations?
Scalar polarisation is what longitudinal waves like sound waves have. Vector polarisation is what motion-in-one-transverse-direction waves like water waves and light waves have. Tensor polarisation is what motion-in-two-transverse-directions waves have. The paper you cite is saying that the evidence is in line with theory and gravitational waves traveling in the z direction are "stretch then squish" in the x direction, "squish then stretch" in the y direction, and nothing in the z direction.
ewq said:
not sure what was the goal of this post?
You reveal the answer in your next line.
the reality behind physical units of measurement is not arbitrary and subject to our consensus, gravity waves either stretch them or not,
The definition of physical units of measurement is subject to our consensus. Gravitational waves either stretch the arms of the LIGO detector or they don't. That was my take-away on the goal of the post.
I have seen discussions of gravitational waves use both approaches. Some approaches stress the physical distance, defined ultimately by the SI definition. This changes because the round-trip light time changes, and that's how the SI system defines distance. Other approaches use a convenient set of coordinates defined by a set of free-fall observers. In this approach, the number associated with an observer on each mirror does not change, by definition.
Both approaches can provide insight and are commonly used.
I suspect many people do not use the modern SI definition of distance, and are confused about what happens according to their own views, which in some cases may not be fully thought out and hence not fully explainable. One can't hit a moving target such as an unspecified definition, but one can attempt to address the issue of what happens from a pre-relativistic definition of distance, which was based on rigid rods, physically implemented out of steel bars.
I haven't seen any discussion of this in textbooks, so the answer will necessarily be my own, not a textbook answer. My answer to this is that the SI definition in this case best approximates what a steel bar would measure. Basically, according to my take, measuring the round-trip time of light is by the principle of the constancy of the local speed of light is simply a better implementation of a "rigid ruler". The fact that this is the SI definition of distance supports the view. If you regard the SI definition of distance as being a refinement of how to accurately measure distance, then one can accept that's the definition want to use it as the "physical" distance, and one can regard other notions of distance (such as assigning constant coordinates to inertial objects) as "non-physical". Non-physical doesn't mean useless, some of these notions can be very useful in understanding. But one needs a connection between the math, and what one can actually measure.
The complicating factor here is that rigid objects don't actually exist in a general curved space-time :(. But that seemingly alarming discussion might best belong in another thread. My personal take is that it's not vital to understanding GW's, but to justify my take requires some rather advanced mathematics.
It doesn't take much math to demonstrate a simple example to demonstrate that "rigid" two dimensional surfaces don't exist on the two dimensional surface of a 3d manifold unless the object and it's surface manifold is highly symmetrical. This won't explain why I don't think this issue isn't vital to explaining GW's, but it can be interesting in its own right, though it's a bit of a digression. I'll take the risk of explaining further, with the suggestion that followup questions probably belong in a different thread.
Let's set some ground rules. To keep things simple, we have some 3 dimensional object, and we treat it's surface as a 2d manifold. Then we address the issue of whether we can construct "rigid" objects on this 2d manifold. What do we mean by a rigid object? We could use a Born's definition, but a good treatment of that gets rather mathematical (and seems hard to find elementary treatments, a lot of the original papers aren't in English as well). I'll suggest that the notion of congruent geometric figures (such as triangles) serves as a good notion of rigidity. Basically, if all triangles are congruent, then we can move a triangle from one spot to another without changing its shape. We can break up other shapes into triangles, and then argue that if all the triangles are congruent, so are the larger figures.
But when we look at the sum of the angles of a triangle on a curved surface (such as a sphere), we start to see the issues. The sum of the angles of a triangle on a plane is always 180 degrees, but this is not true in spherical geometry. It's rather well known that the sum of angles of a spherical triangle is greater than 180 degrees, and depends on the size of the triangle. (I regard this as not being "much math", though i suppose readers unfamiliar with spherical trig might disagree. But it's certainly a lot simpler math than a full understanding of General Relativity and Riemannian geometry, though it can be a useful motivational tool for why we need Riemannian geometry).
If we only demand that triangles of the same size be congruent, we can get around this issue on a sphere. We go from "all triangles are congruent" to "all triangles of the same area are congruent". Unfortunately, when we consider more general cases, such as a flat geometry with a "bump", we see that we just can't make all triangles congruent. If we ask that all triangles be congruent, we can't have the sum of the angles be 180 degrees at one locaction, and some different number at a different location. But if we move a triangle with three equal sides from a location "on the bump" to a location "off the bump", the sum of it's angles changes (as long as the triangle has a finite area). So, we are lead to the notion that saying that "all triangles" are congruent is simply wrong, which then suggests that there are severe difficulties with "rigid objects" as a definition of distance.
Sorry, this got rather long. But I'll try to summarize my point. I believe that pre-relativistic notions of distance relied on "rigid rulers", and the lack of rigid objects on curved manifolds leads to a lot of confusion about what distance really is. Unfortunately I can't point to the literature as to what the "real" definition of distance is, because as near as I can tell there isn't much agreement on how best to formulate it. As a consequence, students wind up with little guidance on this point. I can point out that relying on "rigid objects" to define it is going to cause some issues. And I think it's fair to say that the previous incarnation of the definition of distance used "rigid rulers", so I don't think I'm too far off in suggesting that this is the source of a lot of confusion about the nature of distance.
I should stop here, but I want to add one more thing. I believe it can be fruitful to go from the notion that "all traingles are congruent" to "all sufficiently small triangles are congruent". But I haven't seen any text actually take this approach. I believe, though, that it could be used to motivate Reimannian geometry.
I agree with this. What's more, so does GR, in the sense that GR predicts that a steel bar placed along an arm of LIGO would also contract and expand--as could be verified, relative to the current SI definition of length, by mounting a mirror on the far end of such a bar and a laser emitter/detector on the near end, and seeing the round trip light travel time change as a GW passes and the bar vibrates (i.e., as its length changes sinusoidally) in response.
In fact, the original proposal for GW detection, by Joseph Weber, was to use bars (he used alumininum, not steel, IIRC) with piezoelectric sensors to detect the vibrations induced by GWs. He even claimed, IIRC, to have detected actual GWs. But more recent calculations have made it pretty certain that he couldn't have--bar detectors simply aren't sensitive enough. One key reason why can be seen by imagining a bar laid along an arm of LIGO: the bar's length will change in response to a GW, but not by as much as the arm length between the actual LIGO mirrors, because the bar's tensile strength will resist the length change, whereas there is nothing to resist the length change between the actual LIGO mirrors. So LIGO responds fully to the GW signal, whereas a bar would only partially respond, hence would be less sensitive.
Aren't metallic bars sensitive in the range of their resonance frequency only?
Yes. Outside their band they have little sensitivity. Q values used are quit high so the effective bandwidth is often less than 1Htz.
Yes, as @Paul Colby has said. That's another reason why bar detectors were not pursued more: in order to detect a wide range of frequencies, you would need to build many, many bar detectors with different sizes of bars, whereas you can just build one interferometer to do the same thing.
With Ligo's arms being 4km long, and given that the speed of sound in steel is about 6000 meters/second or so, a steel bar 4km long wouldn't be terribly rigid. It'd take about 2/3 of a second for a push on one end to reach the other :(.
In contrast, it takes light only 20 microseconds to travel 6km.
Yes. The interaction of GW with isotropic materials such as steel is through traction forces applied to the bar boundary. All the internal forces at a point interior are canceled by surrounding matter. So the speed of propagation of mechanical vibration induced on the boundary really effects the coupling to GW. This is why great care is taken to mount the LIGO mirrors so they are essentially inertial along the detector beam.
True, but it would still be a lot more "rigid", in terms of its response to a GW, than LIGO's actual arms. The relevant criterion is not how long it would take a sound wave to travel the length of the arm, but how constrained the local motion of a given atom in the steel bar is, compared to the motion of the actual LIGO mirrors. The answer to that is that the steel bar's atoms are a lot more constrained.
isn't the experiment to measure distance of free space between to points, specifically to not measure the length of some rigid object. as has been pointed out the gw won't "show up" as clearly if passing through something "rigid".
Just to understand you correctly. Does "a lot more constrained" concern the case that the steel bar isn't in resonance with the GW? So it means even though the mirrors being fixed at the ends of the steel bar aren't in free fall the distance between them would still change, however much less compared to the LIGO assembly.
To make the steel bar "ring" at one of its resonant frequencies you need sound waves moving in opposite directions along the bar interfering constructively, creating a standing wave.
Is your point then that there simply isn't enough time to create a standing sound wave in the bar? I'm not that familiar with the details of the GW detection, but I had imagined that this GW is not a very long wave train, just a pulse, really. All that LIGO does is detect the peak of that wave? And the amount of time that that peak spends passing through LIGO is on the order of 20 microseconds?
I think I understand the other point being made, which is far more fundamental: A LIGO leg made of a metal bar, or indeed any material bar at all, would be way too rigid to detect a GW, which is why the basic design of LIGO involves mirrors at the leg ends that are as close to unattached as possible. That is, free to move with as little constraint as possible, given the design parameters.
I found in wikipedia that "in longitudinal waves, such as sound waves in a liquid or gas, the displacement of the particles in the oscillation is always in the direction of propagation, so these waves do not exhibit polarization", so your above explanation (about scalar polarization, at least) appears wrong ... I need some citations, if possible. I searched 2 days and didn't find a clear explanation on this matter (scalar/vector/tensor polarization).
Maybe they didn't check at all if the signal is consistent with a longitudinal wave ... Or maybe pure tensor polarization means something else (may include longitudinal oscillations) ... I really need to know/understand what they found and meant about polarization, how https://dcc.ligo.org/public/0145/P170814/010/GW170814.pdf did stretch the interferometers arms in relation with the propagation direction.
If anyone else can help, please do. PeterDonis maybe ...
No, it means that the amplitude of the bar's vibrations is much smaller than that of the actual LIGO arms' vibrations. And the amplitude is what determines the sensitivity of the device--the larger the amplitude for a given GW, the more sensitive the device is (i.e., the weaker the GW that the device can detect).
That discussion isn't applicable to gravitational waves anyway, because it's talking about waves in a medium made of atoms, which spacetime isn't. (Similar remarks apply to light waves in vacuum.)
@Ibix already answered that: per the paper you referenced, they did, and it isn't. It's consistent with tensor polarization, also called "spin-2", which is transverse and is described, for example, on p. 5 here:
http://www.physics.usu.edu/Wheeler/GenRel2013/Notes/GravitationalWaves.pdf
Ah, I see, thanks.
Thanks. I just wonder why the bar has still some sensitivity, though little, "outside their band" which seems extremely narrow. What is the reason for this?
The reason to choose a narrow band is sensitivity. Basically, in any detection it's ultimately about received power versus the competing noise. Restricting the band reduces the available signal power but the corresponding noise is further reduced. The Q of a resonator, mechanical or electric, is the ratio of the power lost per cycle divided into the power stored. A high Q resonator looses energy more slowly than a low Q one because there are less loss. There is a very general relation between energy loss and noise in a detector (due I believe to Einstein but I could be wrong on this) called the fluctuation dissipation theorem. Bar detectors are designed to maximize the signal to noise in their band of operation. Received power for a bar detector is the energy transferred from the GW into mechanical vibration which can last well after the GW passes. Clearly driving a resonator on its resonant frequency imparts more energy to the resonator than driving off resonance.
I suppose my point is that the equivalence between the SI definition of distance and the old prototype meter bar (steel ruler) definition only works when the rulers are short enough. Unfortunately, being literal and taking a 4km ruler, a steel ruler wouldn't be rigid enough for my favorite analogy to apply directly.
Working around the fact that steel rulers aren't perfectly rigid though is something that people were used to back in the days when the definition was used. It was generally understood that the "definition" of distance in this manner did not mean that forces acting to distort the ruler distorted the concept of distance. Rather, it was intended that a force-free "ruler" be used to measure the distance.
So ideally we'd have a ruler unaffected by gravity. Unfortunately, such a thing has to be defined, as it doesn't exist physically. Gravity affects everything. I use the SI definition of distance, and furthermore I suggest thinking of the SI concept of distance as being an idealized steel bar, that is simply "more rigid" than steel could possibly be, because the speed of sound in steel is just so low in comparison with the speed of light.
Ultimately, this approach has difficulties over large distances. But the distances involved in the case of Ligo (4km) are simply not large enough to be an issue as long as we use a ruler that's not limited by the speed of sound in steel.
The paper you linked references (their 11 and 12) work by Eardley, Lee and Lightman in Phys Rev D. That is here:
https://journals.aps.org/prd/abstract/10.1103/PhysRevD.8.3308
...but is behind a paywall. Searching on the title of that paper led me here:
https://ntrs.nasa.gov/search.jsp?R=19730012613
...which is by the same authors plus Wagoner and Will, is free to download, and gives an overview. General metric theories of gravity permit up to six polarisation modes for gravitational waves (including a pure longitudinal mode), but general relativity permits only two purely transverse tensor modes. The paper you linked provides experimental evidence strongly consistent with GR's pure transverse tensor modes and inconsistent with other modes.
Terminology seems to vary a bit, but Eardley et al clearly regard the pure longitudinal mode as a polarisation state. I agree there's little point in discussing the polarisation state of a pure longitudinal wave, but for waves that permit (or may permit) both transverse and longitudinal oscillation you can break the motions down into components including ones parallel to the direction of motion. And pure parallel motion is a polarisation - at least following the terminology of your linked paper.
I may have the classification slightly wrong. The authors of your linked paper may be regarding the longitudinal mode as a vector polarisation and what Eardley et al call the ##\Phi_{2,2}## mode as a scalar polarisation. Either way, the current evidence is against longitudinal oscillation.
Paul Colby said:
The reason to choose a narrow band is sensitivity. Basically, in any detection it's ultimately about received power versus the competing noise. Restricting the band reduces the available signal power but the corresponding noise is further reduced...
Thanks for this explanation.
Unfortunately I addressed my question ambiguous. I was a bit surprised that you said "Outside their band they have little sensitivity". In this case with the mirrors fixed at the ends of the steel bars (preventing their free fall in the horizontal plane by this) and taking into account that the band is very narrow I wouldn't expect any sensitivity at all outside the band. Would you mind to comment on this?
Still another case. If the mirrors would be fixed to the Earth instead would the sensitivity (hereby neglecting the noise) just be markedly less compared to the LIGO assembly or almost zero? I'm asking this because in pop-science one can read quite often that the whole Earth is squashed and stretched if a gravitational wave passes by. It is even argued sometimes that the only purpose to suspend the mirrors is to avoid the environmental noise.
I'll try. Mechanical vibrations of a solid obey an equation of motion subject to boundary conditions. For LIGO level GW these equations of motion are essentially,
##\rho \ddot{u_k} = T_{jk,j}##​
where indices run over just space coordinates which are Cartesian. This equation is what ##F=ma## becomes for a continuous material. The vector, ##u_k(x,t)##, is the displacement of the material from it's reference (equilibrium) position. The ##T_{jk}## is the mechanical stress tensor. As usual we're using the the summation convention and ##X_{,j}=\partial_j X##. In GR things are not Cartesian so one must use coordinates in which these equations are valid if one wants to get the correct answer using them. These coordinates are known as the TT (for Transverse Traceless) coordinates. In these coordinates the metric strain, ##h_{jk}##, has only space components (hence GW are transverse). For very small strains, the stress is proportional to the strain in linear elastic materials like steel. For isotropic materials the applied GW stress has the property,
##T_{jk,j} = 0##​
which implies the interior material is not accelerated relative to it's reference position by a LIGO level GW. In fact, all material acceleration is due to forces that appear on the boundary of the material due to the GW. For an interior bit of matter, say an atom, to be accelerated it must be from the acoustic (shear) wave originating from the boundary, hence all the discussion of speed of sound in the material.
Now, your question was about mirrors mounted on the bar ends. The relative distance between the end points is the sum of the physical distance determined by the metric (which includes the metric strain in the TT gauge) and the change of the reference position of the endpoints. An exact answer to this is quite complicated. At very low frequencies where the period of the GW is much much longer than the acoustic propagation time between the mirrors, the reference position will quite nearly cancel the metric distance change between the mirrors. If the period of the GW is much shorter than the acoustic transit time then the distance between the mirrors would be dominated (ideally of course) by the GW. In between these cases is the resonant case where all bets are off.
I hope this covers some of your questions.
To put it in Layman terms could one say that if "the acoustic propagation time between the mirrors" is negligible compared to the "period of the GW" then the amplitude of length changes between the mirrors attached to the bar ends is (almost) zero? Which would mean that the sensitivity is zero.
What does "the distance between the mirrors would be dominated (ideally of course) by the GW" mean in terms of sensitivity or amplitudes respectively?
My first impression was "dominated" means that the distance between the mirrors chances as if they were in free fall, but this makes no sense of course.
##x##, a real number, dominates, ##y##, if ##|x| >> |y|## in this context.
I know this is confusing having struggled long and hard myself. The GW changes the distance between points as a function of time and space. This is what time and space dependent metrics do or mean. When a GW wavefront hits a hunk of matter it suddenly finds itself squished or stretched. It responds, of course, but only on a time scale commensurate with the velocity of sound in the material. In this limit the ends of the bar and the mirrors are in free fall. I say ideally because at length changes of ##10^{-21} L## or smaller a metal bar is jiggling like a bowl of jellow being kick down my driveway.
My thesis advisor once complained about an error source in an experiment I was planning. I replied that the source was zero to which he responded "nothing is zero". The meaning, of course, is that things have relative sizes which must be understood quantitatively. The sensitivity is never zero but often negligible is a more useful way to say it.
