Does Lim Inf of Product Equal Product of Lim Infs for Non-Negative Sequences?
The discussion confirms that for arbitrary non-negative sequences \( f_n \) and \( g_n \), the inequality \( \liminf (f_n g_n) \geq (\liminf f_n)(\liminf g_n) \) holds true. However, it establishes that this is the best conclusion possible without additional constraints, as counterexamples demonstrate that equality does not necessarily follow. Specifically, sequences such as \( f_n = (1, \frac{1}{2}, 1, \frac{1}{2}, \ldots) \) and \( g_n = (\frac{1}{2}, 1, \frac{1}{2}, 1, \ldots) \) yield a limit inferior of \( \frac{1}{2} \), which is greater than \( \frac{1}{4} \), the product of their respective limit inferiors.
  • Understanding of limit inferior in sequences
  • Familiarity with real analysis concepts
  • Knowledge of sequences and their properties
  • Basic mathematical proof techniques
  • Study the properties of limit inferior in more complex sequences
  • Explore counterexamples in real analysis to understand limitations of inequalities
  • Learn about convergence and divergence of sequences
  • Investigate the implications of non-negativity in sequence analysis
Mathematicians, students of real analysis, and anyone interested in the properties of sequences and limits will benefit from this discussion.
jostpuur
If f_1,f_2,f_3,\ldots and g_1,g_2,g_3,\ldots are some arbitrary real sequences, is it true that
<br /> \underset{n\to\infty}{\textrm{lim inf}}\;(f_n g_n) = (\underset{n\to\infty}{\textrm{lim inf}}\; f_n) (\underset{n\to\infty}{\textrm{lim inf}}\; g_n)?<br />
For arbitrary \epsilon &gt;0 there exists N\in\mathbb{N} so that
<br /> n &gt; N\quad\implies\quad f_n &gt; \underset{k\to\infty}{\textrm{lim inf}}\; f_k \;-\; \epsilon,<br />
so
<br /> \underset{n\to\infty}{\textrm{lim inf}}\;(f_n g_n) \geq \underset{n\to\infty}{\textrm{lim inf}}\big((\underset{k\to\infty}{\textrm{lim inf}}\; f_k \;-\; \epsilon) g_n\big) \;=\; (\underset{k\to\infty}{\textrm{lim inf}}\; f_k \;-\; \epsilon) (\underset{n\to\infty}{\textrm{lim inf}}\; g_n),<br />
which implies
<br /> \underset{n\to\infty}{\textrm{lim inf}}\;(f_n g_n) \geq (\underset{n\to\infty}{\textrm{lim inf}}\; f_n) (\underset{n\to\infty}{\textrm{lim inf}}\; g_n),<br />
but I don't know how to do the other direction.
edit: I just realized I'm assuming \underset{n\to\infty}{\textrm{lim inf}}\; g_n \geq 0 in the calculation, although it was not my original intention, but I think I'll try to not fix it in the remaining editing time. (Actually assuming \underset{k\to\infty}{\textrm{lim inf}}\; f_k - \epsilon \geq 0 too...)
edit edit: In fact I think I'll add the assumption that the sequences are non-negative, because otherwise I have a counter example (f_n)_{n\in\mathbb{N}} = (1,-1,1,-1,\ldots), (g_n)_{n\in\mathbb{N}}=(-1,1,-1,1,\ldots).
I think I got this thing solved. If f_1,f_2,f_3,\ldots and g_1,g_2,g_3,\ldots are some arbitrary non-negative sequences, then
is the best one can say about the liminfs. One counter example for other direction is
<br /> (f_n)_{n\in\mathbb{N}} = (1,\frac{1}{2},1,\frac{1}{2},\ldots),<br /> \quad\quad<br /> (g_n)_{n\in\mathbb{N}} = (\frac{1}{2},1,\frac{1}{2},1,\ldots),<br />
because
<br /> \underset{n\to\infty}{\textrm{lim inf}}\;(f_n g_n) = \frac{1}{2} &gt; \frac{1}{4} = (\underset{n\to\infty}{\textrm{lim inf}}\; f_n) (\underset{n\to\infty}{\textrm{lim inf}}\; g_n).<br />
Thank you very much.
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
