Mentz114 said:
I'd like to point out that the quote made by the OP ( something I said in another thread) was in the context of the cosmic expansion, and refers to the event horizon ceated by the expansion. The largest red-shift observed is about 7.
I did actually ask this
I don't think there is any transmitter in the universe that is moving fast enough to cause doppler shift down to below ELF, is there?
Perhaps I was insufficiently clear, since we were talking about telescopes and light, I assumed the doppler shift was of light. EMR which is already prettly low can be shifted lower, to below ELF, but I meant light - there is no transmitter moving fast enough (relative to us) to doppler shift visible light down to below ELF. What you say here confirms that since the relevant equation is (rearranged from wiki, to make it easier to write here)
z + 1 =(frequency emitted)/(frequency observed)
Using a frequency emitted in the middle of green (575 terahertz) and z=10 (the highest as yet unconfirmed value that you quoted), this gives us
11 = 575 tHz / (frequency observed)
frequency observed = 575 tHz / 11 = 52 tHz
This is at the lower end of the
http://en.wikipedia.org/wiki/Terahertz_radiation" and it is difficult to detect in our atmosphere, due to absorption. As wiki indicates, it was challenging to detect at all until the 1990s. Challenging, not impossible.
If you got an even greater redshift, enough to push the frequency even lower, it is actually easier to detect the radiation, as you get into microwaves, and even radiowaves.
However, the values of z you are talking about here are magnitudes higher than observed.
Mentz114 said:
I don't know why the OP won't acept the simple truth that there is a lower limit of frequency and/or amplitude that our instruments will probably never overcome.
Frequency, no, amplitude, yes. But as Russ Watters pointed out, with the will we could feasibly make more and more accurate detectors, until it gets ridiculous and you are devoting planet sized detectors to detect weak (low amplitude) signals, which probably will be drowned out anyway in all the stronger -
local - signals around due to the frequency spread associated with square waves (emitted for example from the equipment you have to use to build the detector itself).
Note however, that in the original post I said:
we might have problems with weak signals but not lowish frequencies
Weak signals = low amplitude. Perhaps I should have made that more clear, but I thought it was obvious at the time.
cheers,
neopolitan
