Calculating Limit as x-->pi/4: Solve Tan(x-pi/4)+1/x-pi/4
  • Thread starter Thread starter CalculusHelp1
    Calculation Limit
The limit as x approaches π/4 of the expression [tan(x - π/4) + 1] / (x - π/4) does not exist. The numerator approaches a positive value while the denominator approaches zero, resulting in a limit of +∞ from the right and -∞ from the left. This confirms that the limit is undefined due to differing one-sided limits. The discussion emphasizes that this limit cannot be transformed into a derivative form, as it results in "1/0" rather than the "0/0" form required for L'Hôpital's Rule.
  • Understanding of limits in calculus
  • Familiarity with the tangent function and its properties
  • Knowledge of L'Hôpital's Rule for evaluating indeterminate forms
  • Basic derivative concepts and notation
  • Study the application of L'Hôpital's Rule for limits resulting in "0/0" forms
  • Explore the behavior of the tangent function near critical points
  • Review the concept of one-sided limits and their implications
  • Learn about the continuity of functions and how it affects limits
Students studying calculus, particularly those focusing on limits and derivatives, as well as educators looking for examples of limit evaluation techniques.
CalculusHelp1
Calculate the limit as x-->pi/4 of [tan(x-pi/4)+1]/x-pi/4
lim h-->0 of [f(x+h)-f(x)]/h = f'(x)
lim x--->a [f(x)-f(a)]/(x-a) = f'(x)
I've attempted to turn this equation into the form f(x)-f(a)/x-a by letting f(x)=tanx and a=pi/4
This turns into -[-tan(x+a)-tan(a)]/x-a...which isn't the correct derivative form. .I've tried other methods which also turn into similar garble (a minus sign backwards, x-h rather than x+h and the like).
Can anyone see what the problem is? Thanks
The limit
\lim_{x\rightarrow \pi/4}{\frac{\tan(x-\pi/4)+1}{x-\pi/4}}
Is of the form "1/0". Thus the limit is always +\infty or -\infty or it doesn't exist (if the left limit does not equal the right limit). Which one is it?
Oh is is actually this easy?
In that case, I would think since the numerator will always be positive regardless of which side the limit approaches from, and the denominator will switch signs depending on which side it approaches from, then the limit from the left will be -infinity and will be +infinite from the right, then the limit will not exist.
Are you sure there isn't a way to do this with derivatives? I thought this is what the question was getting at
Yes, I know it looks a lot like a derivative. But this method is definitely simpler then to change the limit into a derivative (if there is a way of doing that).
I don't think that you can change this limit into a derivative-limit. A derivative will yield "0/0", while this is "1/0".
Well, if the question was
\lim_{x\rightarrow \pi/4}{\frac{\tan(x)-1}{x-\pi/4}}
Then you can do some derivative-stuff. But I don't really see a possibility here...
Okay that makes sense. Thanks for the help
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
16K
