Limit of Sum: Understanding the Equation and Correcting Common Mistakes
  • Thread starter Thread starter Steve Turchin
    Limit Sum
The limit of the sum lim_{n \rightarrow \infty}{\frac{1}{n^2} \sum_{k=1}^{n} ke^{\frac{k}{n}}} is incorrectly calculated as zero, while the correct limit is one, as confirmed by Wolfram. The discussion highlights a common misconception that the limit of a sum equals the sum of the limits, which is not applicable in this case due to the nature of the terms involved. To accurately compute the sum, participants suggest starting with the known sum formula for k and applying calculus techniques. The final limit can be expressed as the integral lim_{n \rightarrow \infty} \int_0^1 xe^x \, dx, emphasizing the importance of understanding Riemann sums. This discussion clarifies the correct approach to evaluating the limit of the given sum.
Steve Turchin
## lim_{n \rightarrow \infty}{\frac{1}{n^2} \sum_{k=1}^{n} ke^{\frac{k}{n}}} ##
## lim_{n \rightarrow \infty}{\frac{1}{n^2} \sum_{k=1}^{n} ke^{\frac{k}{n}}} \\
= lim_{n \rightarrow \infty}{\frac{1}{n^2} (1e^{\frac{1}{n}}+2e^{\frac{2}{n}}+3e^{\frac{3}{n}}+\ldots+ne^{\frac{n}{n}})} \\
= lim_{n \rightarrow \infty}{\frac{e^{\frac{1}{n}}}{n^2} +\frac{2e^{\frac{2}{n}}}{n^2} + \ldots + \frac{e}{n} } = 0 ##
I know the limit equals to 1 (Wolfram). Isn't the limit of a sum equals to the sum of the limits? What am I doing wrong?
It looks like you are saying that since each individual term in the sum goes to zero, the infinite sum of those small terms will also be zero. This is not true.
Likes Steve Turchin
Thank you for the reply. It's a sum of ## n ## terms.
Any tips on how to calculate an exact form of the sum: ## \sum_{k=1}^{n} ke^{\frac{k}{n}} ## ?
I would recommend starting with the assumption that the exponential term is on the order of 1.
What is
## \sum_{k=1}^n k ##?
That should get you started in the right direction.
Likes Steve Turchin
The limit is ##\int_0^1 xe^x \ dx##. Check Rieman sums on Wikipedia to see how it works
Likes Steve Turchin and RUber
For fixed ##n## this is just the sum ##\sum_{k=1}^n k x^k##, where we substitute ##x = e^{1/n}## at the end. That is a standard sum, and can using Google, for example. However, if you want to get it for yourself you can do it using a bit of calculus. For any ##x## (before the substitution) we have
\sum_{k=1}^n k x^k = \sum_k x \frac{d\, x^k}{dx} = x \frac{d}{dx} \sum_{k=1}^n x^k.
Use the well-known formula for the sum ##\sum_{k=1}^n x^k##, take the derivative of that formula wrt ##x##, then multiply by ##x##. Finally, substitute ##x = e^{1/n}##.
Likes Steve Turchin
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
