maverick6664 said:
more basic way is
\frac {x^{1/2}-x^2} {1-x^{1/2}} = \sqrt{x} \frac {(1 - \sqrt{x}^3) } { 1 - \sqrt{x}} = \sqrt{x} (1+\sqrt{x} + \sqrt{x}^2)
Isn't it clear? no law or rules...
if you remember 1-y^n = (1+y+y^2+ \cdots +y^{n-1}) (1-y)
or simply
1-y^3 = (1+y+y^2)(1-y)
"back to basic" is often useful
Ooops... This approach looks familiar. Have you had a look at post #7??
Hurkyl said:
Sometimes, you have to make an expression more complicated before you can simplify.
Hmm...
Hurkyl said:
But you can still do it the "hard" way by writing the whole thing as a function of \sqrt{x}..
And so, my approach is classified as a hard way?
frozen7 said:
By the way, is \frac{\sqrt{x} - x ^ 2}{1 - \sqrt{x}} = \frac{\sqrt{1.01} - 1.01 ^ 2}{1 - \sqrt{1.01}} = 3.03002 \approx 3 a general answer checking method?
In case you just have your calculator with you, then yes, it is. I often use it to check whether my answer is correct or not.
It's based on the idea that when you choose an
x near 1, the expression will evaluate to some value very close to 3 (since
x approaches 1, the expression will approach 3).
But, watch out for rounding error. For example:
\lim_{x \rightarrow 0} \frac{1}{\sin ^ 2 x} - \frac{1}{x ^ 2} = \frac{1}{3}
If you choose x = 0.01, plug that in your calculator (in
radian mode), you'll have:
\frac{1}{\sin ^ 2 0.01} - \frac{1}{0.01 ^ 2} = 0.33334 \approx \frac{1}{3}
But if you choose x = 0.00001:
\frac{1}{\sin ^ 2 0.00001} - \frac{1}{0.00001 ^ 2} \approx 0
So choose the x wisely so that it's close
enough, but not
too close to 1 (or 0, or whatever value
x tends to.), so the calculator can evaluate the expression with the smallest rounding error.
