Limit Point of a Set: Definition, Center Point & Empty Set
  • Context: Graduate
  • Thread starter Thread starter xanadu
    Limit Point Set
8 replies · 6K views
xanadu
I've been reading Shilov's book and the definition of a limit point is as follows: x is a limit point of A if every neighborhood of x (any open ball centered at x with arbitrary radius r) contains at least one point y distinct from x which belongs to A.
I feel that from this definition a point at the center of the set would be a limit point. If that is the case then from what I understand the set B of all limit points of A is a superset of A.
However there is an exercise which says find a set A that is not empty and the set of limit points of A is empty. What could I be missing here?
What do you mean by 'the center of the set'?
As for your exercise, think about the integers or the naturals.
If by "a point in the center of the set", you mean, "a point that has a neighborhood of points also in the set", then that's fine. Note that if you mean a geometric center, you are assuming something that a topological set does not necessarily have, a metric, which is a function assigning the distance between two elements of the space (some topological spaces are not even metrizable!).
a set with the discrete topology for instance.
Reread the definition and put a huge emphasis on the word "distinct".
Maybe consider what the limit points of the following sets in R:
The empty set (even though the problem says it isn't a solution)
R itself.
The subset of the integers
The closed unit interval [0, 1]
The open unit interval (0, 1)
The half open unit intervals (0, 1] and [0, 1).
Singleton sets {0}, {1}, {e}, etc.
The subset of the rationals
a set with the discrete topology has no limit points.
what about the converse? If a topological space has no limit points is it discrete?
Note that the limit point does not need to be an element of the set. For example. consider the following union of intervals on the real line: (0, 1) U (1, 2). The number 1 is a limit point of this set even though it isn't an element of the set. 0 and 2 are also limit points of this set, and they lie outside of the set as well (without being in a gap). -1 is not a limit point of the set (why?).
geometrical concept of a limit point of a set is that it is a very nearest point to that set ,means attached with that set or in other words attached with elements of that set .
haider_uop99@yahoo.com (pakistan)
1 is limit point of A= (0,1)U(1,2) , because any open interval containing 1 contains infinite points of A .
