Limits and integrating over a singularity
Evaluating a definite integral over a singularity, such as -∫_{-1}^3 (1/x^2) dx, typically involves splitting the integral around the singularity and taking limits. The discussion highlights a common misconception where one might incorrectly apply the same limit to both sides of the split integral, leading to a cancellation of divergent terms and a misleading finite result. The key error lies in not recognizing that the limits for each integral must be one-sided, as the behavior of the function differs on either side of the singularity. The conversation also touches on the importance of ensuring that the integration bounds do not include the singularity itself. Ultimately, the correct approach involves understanding the nature of the singularity and applying appropriate limits to avoid erroneous conclusions.
CuriousParrot
Suppose one needs to evaluate a definite integral over a singularity, like: -\int_{-1}^3 \frac{1}{x^2} dx
The textbook way to do so is to split the integral into two parts around the singularity and take the limit, like so:
\lim_{b\rightarrow 0} -\int_{-1}^b \frac{1}{x^2} dx
and:
\lim_{c\rightarrow 0} -\int_{c}^3 \frac{1}{x^2} dx
and then add the results of the two expressions above. In this case, the integral is not convergent, and one obtains an infinite result from those evaluations.
So far, so good. But here's a question:
What's wrong with just using the same limit for both integrals? Like this:
-\int_{-1}^3 \frac{1}{x^2} dx = \lim_{c\rightarrow 0} \Bigr( -\int_{-1}^c \frac{1}{x^2} dx -\int_{c}^3 \frac{1}{x^2} dx ~\Bigr)
= \lim_{c\rightarrow 0}\Bigr(\frac{1}{x}\Bigr|_{-1}^c + \frac{1}{x}\Bigr|_c^3~\Bigr)
The 1/c terms cancel each other out, and a finite result remains. In fact, the divergent terms would always cancel out when trying to integrate over a singularity in this way. Clearly, this is a wrong answer, so an invalid step has been performed above. But what part was wrong, and why? Perhaps it is an error to apply the same limit process to both sides of the split integral at the same time. If so, why can't you do that?
This should be
$$ \lim_{b\rightarrow 0^-} -\int_{-1}^b \frac{1}{x^2} dx$$
Similar for the one just below, except that the limit is as c → 0 from above.
CuriousParrot said:
and:
The two limits are different, and are both one-sided, which you don't show above. In the first integral, the limit is as x → 0 from the left, while in the second integral, the limit is as x → 0 from the right.
Thanks for the reply, Mark!
There's something I still don't get, though: shouldn't the limiting behavior of the function be exactly symmetrical on the left and right sides of the singularity (for some functions, like this one)? And as such, wouldn't those 1/c and 1/b terms still cancel each other out?
and:
I think your arithemetic is wrong:
-\int_{-1}^{2} \frac{1}{x^2}dx=-\lim_{\epsilon\to 0} \left(\frac{1}{x}\biggr |_{-1}^{-\epsilon}+\frac{1}{x}\biggr |_{\epsilon}^{2}\right)= \lim_{\epsilon\to 0}\left(-\frac{1}{\epsilon}+1+1/2-\frac{1}{\epsilon}\right)\to \infty
Now use the same approach with
\int_{-1}^{2} \frac{1}{x} dx
Ahh, perhaps that's it - I see you set up your inner integration bounds as -e and +e, whereas I just used +c in both cases. So, your range of integration never actually includes the singularity, while mine implicitly did. That sounds like a good reason why I'd get the wrong answer.
Hopefully someone will correct me if my interpretation is wrong, but I think I get it now.
That's called a Cauchy Principal-valued integral and I left off the PV just to be annoying. Really, I should have written it as:
P.V. \int_{-1}^{2} \frac{1}{x^2} dx
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
