Limits of Sequences .... Sohrab Exercise 2.2.7 ....
3 replies · 2K views
Math Amateur
MHB
I am reading Houshang H. Sohrab's book: "Basic Real Analysis" (Second Edition).
I am focused on Chapter 2: Sequences and Series of Real Numbers ... ...
I need help with a part of Exercise 2.2.7 Part (1) ... ...
Exercise 2.2.7 Part (1) reads as follows:
I have managed a solution to this exercise and am posting it because
(1) I am unsure that the proof is valid/correct ... particularly given my arithmetic on ##\epsilon## ...
(2) I did not use Sohrab's hint ... and that concerns me ... but I am also interested in how Bernoulli's Inequality is used in this proof ... I can see how to simply involve Bernoulli's Inequality, but not how to use it profitably ...
2. Homework Equations
The concepts of convergence of a sequence and the limit of a sequence are relevant ... so I am posting Sohrab's text corresponding to these notions ...
3. The Attempt at a Solution
My proof is as follows:
To show ##\text{lim } ( \frac{ 1 }{ 1 + na } ) = 0## where ##n \in \mathbb{N}##We have ##| \frac{ 1 }{ 1 + na } - 0 | = \frac{ 1 }{ 1 + na } \lt \frac{ 1 }{ na }##
Now for ##\epsilon \gt 0## let ##\frac{ 1 }{ na } \lt \epsilon##
Then let ##\epsilon = \frac{\epsilon^*}{a}## so that ##\epsilon^* = a \epsilon## ...
Then we have :
##\frac{ 1 }{ 1 + na } \lt \frac{\epsilon^*}{a} \Longrightarrow \frac{ 1 }{ n } \lt \epsilon^*## ...So ... choose ##N## so that ##\frac{ 1 }{ N } \lt \epsilon^*## ...
So that then we have ... for ##n \gt N## ...
##| \frac{ 1 }{ 1 + na } - 0 | = \frac{ 1 }{ 1 + na } \lt \frac{ 1 }{ na } = ( \frac{ 1 }{ n } ) ( \frac{ 1 }{ a } ) \lt \epsilon^* ( \frac{ 1 }{ a } ) = \epsilon a ( \frac{ 1 }{ a } ) = \epsilon##Is that correct?
and further ...
Can someone please indicate how Bernoulli's Inequality is used in a proof ...
Peter
Math Amateur said:
Then we have :
This step is not justified. Consider ##\epsilon=\frac58, n=1, a=1, n=1##. The first inequality is satisfied but not the second.
I can't see any use for Bernoulli's inequality, but perhaps the author has in mind a different version of it from the one on wikipedia.
For (1) I'd be inclined to try using Corollary 2.1.32(a) with ##\frac1\epsilon## for ##x## and ##a## for ##y##.
Hi Andrew,
I was guided to the following solution by Opalg from the Math Help Boards ...
" ... ... Given ##\varepsilon>0##, choose ##N> \dfrac 1{a\varepsilon}##. ... ... Then ##\dfrac 1{Na} < \varepsilon##, and ...
##n\geqslant N \Longrightarrow \frac1{1+na} <\frac1{na} \leqslant \frac1{Na} < \varepsilon.## ... ... "Thanks for all your help ... I got a number of pointers from your guidance and help ... which is helping me to grasp the basics of analysis ...
Most grateful for all your help ...
Peter
This would be my proof:
Let ##\epsilon > 0## and let ##N \geq \frac{1}{a\epsilon} - \frac{1}{a}##. Then:
##n \geq N \implies n \geq \frac{1}{a\epsilon} - \frac{1}{a}##
##\implies na \geq \frac{1}{\epsilon} -1##
##\implies 1 + na \geq \frac{1}{\epsilon}##
##\implies \epsilon \geq \frac{1}{1+na} = \vert \frac{1}{1+na}\vert##
so we have ##\frac{1}{1+na} \to 0## if ##n \to \infty##
