Line Integral Along a Path: How to Compute and Use Vector Fields
The discussion focuses on computing the line integral of the vector field F = -y'î + x'ĵ along the path defined by c(t) = (cos(t), sin(t)) for 0 ≤ t ≤ π/2. The correct differential line element is derived as dl = (-sin(t), cos(t))dt, confirming the use of Cartesian coordinates is appropriate. The final result of the line integral is established as 0.5π.
  • Understanding of vector fields and line integrals
  • Familiarity with parametric equations
  • Knowledge of differential calculus
  • Proficiency in Cartesian coordinates
  • Study the properties of line integrals in vector calculus
  • Learn about the Fundamental Theorem for line integrals
  • Explore applications of vector fields in physics
  • Investigate the use of Green's Theorem for area calculations
Students studying vector calculus, mathematicians interested in line integrals, and professionals applying vector fields in engineering and physics.
idir93
1. Homework Statement
Vector field is F=-y[itex]\hat{x}[/itex] + x[itex]\hat{y}[/itex]
Compute the line integral along the path c(t)=( cos(t), sin(t) ) with 0≤t≤∏2. The attempt at a solution
i started computing f.dl but how much is dl ? I took it dx[itex]\hat{x}[/itex] +dy[itex]\hat{y}[/itex] I'm not sure if using Cartesian coordinates is right ?
I can's see why you would say " I'm not sure if using Cartesian coordinates is right" when everything is given in Cartesian coordinates. You are given that the line is defined by [itex]c(t)= (cos(t), sin(t))[/itex] so it should be clear that [itex]dc= (-sin(t), cos(t))dt[/itex] and that is dl because it has unit length.
Found it ! it's 0.5∏
  • · Replies 21 ·
