Line Integral for Electromagnetic Force
The discussion focuses on the derivation of the electromagnetic force equation from the line integral expression F = ∫[(Q*λ)*dL*r]/(r^2) to F=∫q*λ*[(xx+ay)/(a^2+x^2)^(3/2)]*dx. Participants clarify the negative components of the unit vector ##\hat r##, which is defined as ##\hat r = -\hat x \cos \theta - \hat y \sin \theta##, and explain the symmetry in the force contributions from charge segments on either side of the midpoint. Key variables such as line charge density (##λ##), total charge (Q), and test charge (q) are defined, emphasizing the importance of understanding these concepts for further studies in electricity and magnetism.
  • Understanding of line integrals in electromagnetism
  • Familiarity with vector notation and unit vectors
  • Basic knowledge of charge density and Coulomb's law
  • Ability to interpret diagrams in physics contexts
  • Study the derivation of Maxwell's equations from fundamental principles
  • Learn about electric field calculations using line charge density
  • Explore the concept of symmetry in electric fields and forces
  • Practice writing and interpreting equations in LaTeX for clarity in physics
Students and enthusiasts of physics, particularly those interested in electricity and magnetism, as well as educators looking to clarify complex concepts in electromagnetism.
gibberingmouther
http://web.mit.edu/sahughes/www/8.022/lec01.pdf
So I'm trying to understand how to get from F = ∫[(Q*λ)*dL*r]/(r^2) to F=∫q*λ*[(xx+ay)/(a^2+x^2)^(3/2)]*dx
Like I don't understand why the x and y components of r are negative, or why "The horizontal r component is obviously zero: for every element on the right of the midpoint, there is an element on the left whose force magnitude is equal, but whose horizontal component points in the opposite direction."
This was kind of a starting point for trying to understand some of the more "fundamental" Electricity and Magnetism equations and ideas, but I got stuck.
I cannot read your formulae well. You should also better explain the physics context the integrals are needed for. Maybe then we'll be able to help you with your problem.
I assume you're referring to the unit vector ##\hat r## which he writes near the bottom of page 7: $$\hat r = -\hat x \cos \theta - \hat y \sin \theta$$ According to the diagram in the middle of the page, ##\hat r## starts at the charge segment dx and points downwards and to the left. His coordinate system is set up as xy systems usually are: x is positive to the right and negative to the left, y is positive upwards and negative downwards. This determines the signs on the components of ##\hat r##.
(Tip: to learn how to write equations "properly", see here: https://www.physicsforums.com/help/latexhelp/)
Draw a new version of the diagram in the middle of page 7, with a second charge segment dx located the same distance x from the midpoint, but on the left side. Draw the unit vector ##\hat r## associated with that second dx. Which way does it point, what are the signs on its x and y components, and how do they compare to the other dx? What happens when you add the contributions from the two dx's, as part of the integral on the next page?
I cannot read your equations. Could you write them in LaTex and also explain what the variables are? What are x and L, what are Q and q, etc.
I figured out how to use Latex. I originally thought I had to use a separate program to format the Latex code but then I re-read the Latex Primer here on Physics Forums and realized that it is much easier than that!
So the math I was stuck on is:
##\vec F = \int (Q \times λ \times dl \times r)/(r^2)## somehow becomes ##\vec F = - \int_{-L/2}^{L/2} q \times λ \times [(x \times \hat x +a \times \hat y)/(a^2+x^2)^{3/2}] dx##
We have a rod of length L horizontally there in space with a charge Q smeared uniformly on it and a test charge q somewhere else with relation to it.
As for the variables
* ##\lambda## = Q / L = the line charge density
* Q is the value of the charge that is uniformly smeared on the rod
* q = value of the test charge in coulombs
* x is the horizontal axis and the rod smeared with charge we're talking about goes from -L/2 to L/2 where L is the length of the horizontal rod
* ##\hat r## is the length from the test charge to a point on the rod and ##\hat x## is the x component of that distance and ##\hat y## is the y component of it
I just want to start learning some real electricity and magnetism, mainly for fun. I plan to take the electricity and magnetism physics course next semester. So I started with this lecture PDF and I just want to get unstuck. My next physics course won't require calculus, but I want to learn the calculus based part of the physics too so I can eventually understand Maxwell's equations.
