Line Integral of a parametric curve
The discussion centers on evaluating the line integral of the function e^x over the curve defined by x = y^3 from the points (-1, -1) to (1, 1). The initial attempt involved parametrizing the curve with y = t and x = t^3, leading to a complex integral that was deemed insolvable. Participants clarified that the integral should be expressed as ∫_C e^x ds, emphasizing the importance of using the correct differential element for line integrals. It was noted that integrating over arc length (ds) requires proper parametrization, while integrating with respect to x simplifies the problem to a standard integral. The conversation highlights the need for accurate formulation and understanding of line integrals in calculus.
chrisy2012
Evaluate the line integral over the curve C
\int_{C}^{}e^xdx
where C is the arc of the curve
x=y^3
from (-1,-1) to (1,1)
\int_{C}^{}f(x,y)ds=\int_{a}^{b}f(x(t),y(t))\sqrt((\frac{dx}{dt})^2+(\frac{dy}{dt})^2)dt
I tried parametrizing the curve to y=t and x=t^3
therefore dy/dt = 1 and dx/dt = 3t^2
plug this back into the formula, we get
∫ from -1 to 1 (e^t^3)sqrt(3t^2+1)dt
but this is an insolvable integral, anything I did wrong or is there another way?
Your line integral is obviously wrong. You might have typed it incorrectly. It should be:
\int_{C}^{}e^xds
\frac{dy}{dx}=\frac{1}{3y}
\int_{C}^{}f(x,y)ds=\int_{x=a}^{x=b}f(x,y)\sqrt {1+(\frac{dy}{dx})^2}\,.dx
Afterwards, use the substitution \frac{1}{3x^{1/3}}=\tan \theta and evaluate your line integral.
Keep in mind there are three basic ways of integrating over a curve (line integral), you can integrate over the arc-length (ds), but also over the shadow of the curve along the x and y-axis (by dx or dy). Now you wrote it as dx, so that's just a regular integral:
\int_C f(x,y)dx=\int_C f(x,y(x))dx=\int_{-1}^1 e^x dx
If it were ds, then you'd need to use the formula you posted.
But I am suppose to integrate over the arclength(ds). I'm suppose to parametrize the curve with respect to t so that the curve imoves along 1 unit of length per unit of time. That's how I got the bounds for the integral
Post the entire question correctly.
The entire question is posted correctly.
\int_{C}^{}e^xdx
x=y^3
In that case, you won't have any use for the relevant equations that you've posted. :smile:
