Line Integral Problems: Solving for Work and Potential Functions
This discussion focuses on solving line integral problems, specifically calculating the line integral ∫v⋅dr along the curve y=x³ and determining the work done by a force F = (y²+5)i+(2xy-8)j along specified paths. The participants clarify the parameterization of the curve and the decomposition of vectors into their components. The final integral for the line integral is established as ∫(xy + 3x⁴) dx from -1 to 2, confirming the correct approach to solving these problems.
  • Understanding of vector calculus and line integrals
  • Familiarity with parameterization of curves
  • Knowledge of dot products and vector decomposition
  • Basic integration techniques
  • Study the process of parameterizing curves in vector calculus
  • Learn about calculating line integrals in multiple dimensions
  • Explore the concept of conservative fields and potential functions
  • Practice solving problems involving work done by vector fields
Students and professionals in mathematics, physics, and engineering who are looking to enhance their understanding of line integrals and vector fields.
EdisT
Thread moved from the technical forums, so no HH Template is shown.
I'm used to parameterizing however I'm not sure how to solve these types of problems, any help would be much appreciated.
1) Calculate the line integral ∫v⋅dr along the curve y=x3 in the xy-plane when -1≤x≤2 and v=xyi+x2j
2) a) Find the work that the force F = (y2+5)i+(2xy-8)j carries out along two paths ABC and ADC which are composed of perpendicular lines between the points A,B,C,D. A,B,C,D are corners in a square and the corners have the coordinates (0,0),(1,0),(1,1),(0,1) respectively
b) Calculate the work done along a straight line from A to C.
c) Since the work done appears to be independent of the path taken, we expect that the force can be written as the gradient to a potential V. Find the potential-function and show that the difference between the potential at A and C are equivalent to the work done.Attempt at reaching a solution:
1) I substituted y=x3 into the equation then did a normal integral with respect to x. It doesn't seem right to me however I'm used to dS and t so these problems just messed my thinking up.
2) Similar thinking to 1) is messing me up I think. Did normal integrals with respect to x and y.
Here, r is a vector between the origin and a point (x,y) on the curve y = x3.
Do you know how to set up the components of the vector r to describe y = x3 ?
Once you find r, you can calculate dr and substitute into the line integral expression. After calculating v ⋅ dr, then you can start to treat the line integral like a regular integral.
No I have no idea how to split it up, the dot product should be easy enough but I'm more used to x(t), y(t) being given.. How would you split it up?
Do you know how to decompose a vector into its components?
It's been a while... I don't quite remember
You can look up how on the internet. That's what it's for.
Remember, i, j , and k are the unit vectors for a general vector r, such that r = x i + y j + z k
You have a curve described by y = x3. Care to take a guess as to how this curve could be turned into a vector expression?
r=x^3i+yj ?
EdisT said:
r=x^3i+yj ?
What's the independent variable in y = x3 ?
x would be the independent variable, so it would be x^3j?
Correct. r = x i + x3 j + 0 k
Can you calculate dr now?
dr = (i + 3x2) dx
The dot product would be v⋅dr = xy+3x4 dx
The integral would then be: ## \int_{-1}^2 xy+3x^4 \, dx ## ?
EdisT said:
dr = (i + 3x2) dx
Don't forget the j component for the 3x2.
What does y equal when traversing the curve y = x3 ?
SteamKing said:
Don't forget the j component for the 3x2.What does y equal when traversing the curve y = x3 ?
Of course, the integral becomes x^4+3x^4 dx. thank you!
  • · Replies 20 ·
