Line Integrals - Cartesian and Parametric
I'll just do the integral. First, r'= (-a sin(phi), a cos(phi), b/(2pi)) so the integral is \int_0^a (x(t), y(t), z(t))\cdot (-a sin(phi), a cos(phi), b/(2pi)) dt I'll just assume that you can do that integral. If not, let me know. Now, the point is that we can also do the integral directly from (0,0,0) to (a,0,0) then from there to (a,0,b). The integral from (0,0,0) to (a,0,0) is just\
Bunting
85
Hello
Im working on some line integral problems at the moment. The first one is really only a check - I think I've worked it out...
Compute the line integral of the vector field B(r) = x^2 e(sub 1) + y^2 e(sub 2) along a straight line from the origin to the point e(sub 1) + 2 e(sub 2) + 4 e(sub 3). Explain why your answer should be independant of the path of integration.
So quickly - z = 2y = 4x
y = 2x so y^2 = 4x^2 -> dy = 8x dx
thus B(r) = x^2 e + 4x^2
so we integrate this over 0->1 (as we converted all the bits to x) and thus I end with an answer of 11.
The second part I think reads something like "because the line integral depends only on the arc length", but really that's something I read off wikipedia or somewhere so am not particularly sure about :)
The other question is proving more tricky...
Compute the line integral of a vector field F = xe(sub1) + ye(sub 2) + 2ze(sub 3) along a circular helix between the two points (a,0,0) and (a,0,b) parametrized by r = (a cos phi, a sin phi, (b/2*pi) phi). Can you check your result using a different path and why? Do so for example using a direct line.
So as before I might go ahead and say x = y = 1/2 z, but then I wouldn't know where to go with the parametric component to the question. Any pointers in this would be great - I think I have to differentiate the parametric part, but then don't know where to go from there (suspect some cross-producting in there, such as int(r x r') but I am really not very confident any hypothesis I have!
Bunting said:
Hello
What you say you did seems right but the answer is not "11"! Yes, on the line through (0,0,0) and (1, 2, 4), y= 2x and z= 4x as x goes from 0 to 2. Another way of putting that is that r= te1+ 2te2+ 4t3 where I have more or less arbitrarily take "t" as the parmeter (since x= t, I could as easily have used x). Of course, dr= (e1+ 2e2+ 4e3)dt since this is a straight line. Yes, the function to be integrated is, in your terms, x2e1+ 4x2e2 or, in terms of my t, t2e1+ 4t2e2. The dot product is then t2+ 8t2= 9t2. Since x (or t) ranges between 0 and 1, the integral is
[tex]\int_0^1 9t^2 dt[/tex]
That integral is not 11!
There are two ways to show that the integral is independent of the path. We can always write dr as dxe1+ dye2+ dze3. Since the first component of the function to be integrated involves only x, the second only y, and the third is 0, we can write the dot product as x2dx+ y2dy, no matter what the path is and do those as two separate integrals:
[tex]\int_0^1 x^2 dx+\int_0^2 y^2dy[/tex]
That can be integrated without regard for the path and is the same as the integral above.
The other method is more general. The integral will be independent of the path if and only if the integrand is an "exact differential". That is, if there exist a function F(x,y,z) having the integrand as its differential:
[tex]dF= \frac{\partial F}{\partial x}dx+ \frac{\partial F}{\partial y}dy+ \frac{\partial F}{\partial z} dz[/tex]
which can be integrated by evaluating F at the endpoints no matter what the path is.
Since, for a simple function with continuous partials, the "mixed second derivatives" must be equal, that is
[tex]\frac{\partial^2 F}{\partial x\partial y}= \frac{\partial^2 F}{\partial y\partial x}[/tex]
f(x,y,z)dx+ g(x,y,z)dy+ h(x,y,z)dz is an "exact differential" if and only if
fy= gx, fzz= hx, and gz= hy. In this problem it is easy to see that all of those partial derivatives are 0 and so equal.
No, x= y= 1/2 z is incorrect. I guess you get that from the formula for F= xe1+ ye2+ ze3 but that is NOT the equation for the path. And, no, there is no cross product. The integral of F on a path r is the dot product [itex]F\cdot r[/itex] Since you are given that
[tex]r= (a cos\phi, a sin\phi, \frac{b}{2\pi}\phi)[/tex]
you are given that
[tex]x= a cos\phi, y= a sin\phi, z= \frac{b}{2\pi}\phi[/tex]
so that
[tex]dr= (dx, dy, dz)= (-a sin\phi, a cos \phi, \frac{b}{2\pi})d\phi[/tex]
The function to be integrated is
[tex]F= (x, y, z)= (a cos\phi, a sin\phi, \frac{b}{2\pi}\phi)[/tex]
and so the integral is of the dot product:
[tex]\int_0^{2\pi}(-a^2sin\phi cos\phi+ a^2sin\phi cos\phi+ \frac{b^2}{4\pi^2}\phi d\phi= \frac{b^2}{4\pi^2}\int_0^{2\pi}\phi d\phi[/tex]
Of course, the straight line from (a, 0, 0) to (a, 0, b) is given by
x= a, y= 0, z= bt with t going from 0 to 1. That is r= (a, 0, bt) so
dr= (0, 0, b)dt. The function is given by F= (x, y, z)= (a, 0, bt}. The integral is [itex]\int_0^1 b^2 t dt[/itex]. Check to see if those two integrals are the same. (For exactly the same reasons, the answer should be "yes".)
In general, it would be good to destinguish between "exact" and "closed" forms.
just a few bits I don't understand still, bear with me if you will :)
the first bit you say we need to get the intergral(9t^2), but I could have done that right from the start, AFTER saying B(r) = this and r = that. You later go on to say "The integral of F on a path r is the dot product F.R" - so I do all that but don't really need the dr part, the y = 2x part, or even to integrate x^2 + 4x^2.
Is what your suggesting here to just get B (or F!) and r and dot them to get the line integral ?
For the second part I think you have a few mistakes but I am basically following...
F . dr is what I want to calculate where...
F = (x,y,2z) = (a cos phi, a sin phi, 1/pi phi)
dr = (-asin phi, a cos phi, b / 2 pi) d phi
Then I integrate this - only I don't understand where you have got the limits from!
Sorry for my slow reply to this thread, I work quite a lot and this is the first chance I've had to look back in at it :) I really appreciate the work you have put into it!
Hey, if you are who I think you are... good luck tomorrow I'll be there too :-)
Im scared how all through my life everybody knows me and I know nobody... Maybe I am the guy from the truman show *shifty eyes*
Also, it seems /everybody/ who takes it will be there! :S Evil maths for the lose.
1. What is a line integral in Cartesian coordinates?
A line integral in Cartesian coordinates is a type of integral used to calculate the total value of a function along a specific path or line in a two-dimensional coordinate system. It takes into account both the magnitude and direction of the function along the path.
2. How is a line integral different from a regular integral?
A line integral differs from a regular integral in that it calculates the value of a function along a specific path, rather than over a specific interval. It also takes into account the direction of the function along the path, rather than just its magnitude.
3. What is the formula for calculating a line integral in Cartesian coordinates?
The formula for calculating a line integral in Cartesian coordinates is ∫F(x,y) ds = ∫F(x(t),y(t)) √(dx/dt)^2 + (dy/dt)^2 dt, where F(x,y) is the function being integrated, ds is the length of the path, and dx/dt and dy/dt are the derivatives of x and y with respect to a parameter t.
4. What are some real-world applications of line integrals in Cartesian coordinates?
Line integrals in Cartesian coordinates have many real-world applications, such as calculating work done by a force along a specific path, finding the center of mass of a two-dimensional object, and calculating the flow of a fluid along a certain path.
5. Can line integrals be calculated in parametric coordinates as well?
Yes, line integrals can be calculated in parametric coordinates, which are coordinates that use parameters to define a point on a curve or surface. This allows for a more flexible and efficient way to calculate line integrals, as the path can be described using a single parameter instead of two variables.
