Calculate Line Integrals for Vector Field F on C1 and C2
The discussion focuses on calculating the line integral of the vector field F along two segments, C1 and C2. The user struggles with parameterizing the first segment, C1, and receives guidance on correcting the parameterization to ensure it accurately represents the line from P1 to P2. The conversation highlights the importance of ensuring that the endpoints of the parameterization match the specified points. Additionally, the concept of the curl of F is introduced to determine if the vector field is conservative, suggesting that the integral could be simplified using the gradient method. Ultimately, the user considers evaluating the integral directly from P1 to P3, bypassing P2 for efficiency.
hils0005
Calculate \intF dr if C = C1 + C2 where C1 is the line segment from P1(-1,pi,-1) to P2(0,0,0) and C2 is the line segment from P2(0,0,0) to P3(2,0,4)
vectorF= yz i + (xz - e^(z)siny) j + (e^(z)cosy + xy) k
Im having problems setting up the C1 integral:
I have it parametrized as x=t, y=-pi t z=t, as t goes 0 to 1
r(t)= t i - pit j + t k
r'(t)= i - pi j + k
F= -pi t^2 i + (t^2-e^(t)sin(pit)) j + (e^(t)cos(pit) + pit^2) k
F dot r'(t) = -pi t^2 + pi e^(t)sin(pit) + e^tcos(pit)
I would then take integral dt as t goes from 0 to 1
I think I have answered C2 correctly, I'm not sure if my parameters are correct
Big time-saving hint: What is curl F ?
dF2/dx - dF1/dy =0 z-z=0
dF3/dy - dF2/dz =0 (-e^zsiny + x) + (-x + e^zsiny) = 0
dF1/dz - dF3/dx = 0 y-y=0
Curl test?? how does that help?
So what does that tell you about F?
that it is path independent or conservative?
Yes, which also tells you that you can write F as the gradient of some scalar \varphi...So if you can find such a scalar, you can easily compute the path integral using the fundamental theorem of gradients.
However, the way your original question is worded leads e to believe that they want you to evaluate the path integral along that specific path, so I would use the gradient method only as a check.
hils0005 said:
C1 is the line segment from P1(-1,pi,-1) to P2(0,0,0)...
That doesn't seem right; r(0)=(0,0,0) which is not your starting point, and r(1)=(1,-\pi,1) which is neither your starting point or your finish point!:eek:
x=t-1
y= pi t + t
z=t-1
t goes from -2 to -1,
would that work?
hils0005 said:
x=t-1
y= pi t + t
z=t-1
would that work?
Nope; now your starting point is r(-2)=(-3,-2pi-2,-3) and your finish point is just as incorrect.
Let's think this through logically instead of stabbing blindly in the dark...You know that c1 is the direct line from P1 to P2; so you can write down a general parameterized line for r: \mathbf{r}(t)=(at+b,ct+d,ft+g)...say you let t go from 0 to 1; what must a,b,c,d,f and g be for \mathbf{r}(0) to be P1 and \mathbf{r}(1) to be P2?
x=t-1
y=pit^2
z=t-1
x and z look good, but y isn't even linear in t!...how did you come up with that? Is y(1) really 0?
its late...what else can i say
I don't know what to use for t going from 0 to 1
y=pi t + pi
y(0)=pi
y(1)=2pi
y=pit - pi
y(0)=-pi
y(1)=pi t - pi=0
well now y is linear, and y(1)=0 :smile: , but y(0)=-pi not +pi:frown:
Perhaps you should get some rest and leave this until morning? :wink:
Great idea, thanks for your help
r'(t)= i - pi j + k
Here's a big hint for finding x, y and z,
So, we have (-1, pi, -1) + some t
(-1, pi,-1)+(1,a, b)t
So x= -1+t
I got this by having our original point and taking 0 from our second point and and -1 from the first point.
So, we have -1+[0-(-1)]t=-1+t
Follow this in the same manner for finding y and z.
Actually my intention wasn't to find the scalar potential which itself could be rather tedious, but to show that one could evaluate the line integral from P1 to P3 directly bypassing P2 to save time.
