Line voltage vs phase voltage for base value calculations
  • Thread starter Thread starter anon6912
    Base
anon6912
When calculating base values for current, impedance etc
do we use the line to line voltage or the phase voltage?
What's the reason for using one over the other?
What is a "line to the line voltage"? What is "phase voltage"? I don't understand your question.
My best guess is that he's asking about polyphase AC circuits, likely 3-phase.
I don't know much about 3-phase though.
If you are talking about per-unit system, this is the usual practicce.
Take Total 3-phase power S, as base power,
Take Line-to-Line voltage V, as base Voltage V.
Take Line-Current I, as base Current
Take an Impedance Z, as base impedance
But since you can only select two Base quantities independently, If you say take S and V as the initial base quantities (which is the usual practice) then
I = S / sqrt(3)*V
Now, the Impedance Z is assumed to be that impedance Z, which when connected in Star fashion in a 3 phase line with line-to-line voltage *V* will result in line Current *I*.
So, I hope that now you can find the base impedance Z, from the base voltage V and base Power S.
