Linear Algebra - Characteristic polynomials and similar matrices question
7 replies · 3K views
zeion
For each matrix A below, let T be the linear operator on R3 thathas matrix A relative to the basis A = {(1,0,0), (1,1,0), (1,1,1)}. Find the algebraic and geometric multiplicities of each eigenvalues, and a basis for each eigenspace.
a) A = [tex] \begin{bmatrix} 8&5&-5\\5&8&-5\\15&15&-12\end{bmatrix} <br /> [/tex]
So I tried to find the eigenvalues normally and turns out that was pretty hard.. So I know that similar matrices have the same eigenvalues, then can I just take the eigenvalues of the matrix [tex] \begin{bmatrix} 1&1&1\\0&1&1\\0&0&1\end{bmatrix} <br /> [/tex]
since it is similar to A? Or is it similar?
The eigenvalues of similar matrices are the same but the eigenvectors may be different.
I calculated B but that doesn't seem to make finding eigenvalues any easier..?
Okay nice it seems it's just because I made a mistake in calculating the inverse of P..
turns out it's much easier to find the eigenvalues of B.
..or not. I don't understand why there is suddenly such a computational question when everything else is hardly as hard..
Can I row-reduce a matrix before subtracting lambda and then find the determinant? Or do I have to subtract lambda first?
You have to subtract [itex]\lambda[/itex] first. Think about it. You can reduce any invertible matrix to the identity matrix. If you then subtracted [itex]\lambda[/itex], all the eigenvalues would be 1, which is obviously not the case for every invertible matrix.
