Linear Algebra Concept Question
The discussion revolves around a system of linear equations involving a parameter "a" and the conditions under which the system has no solutions, a unique solution, or infinite solutions. The equations are presented in a standard form, and participants are exploring the implications of different values of "a" on the solution set.
  • Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss the conditions for different types of solutions based on the parameter "a". There is an exploration of the implications of reducing the system to row-echelon form and the interpretation of basic and free variables. Questions arise regarding the case for infinite solutions and the general strategy for solving such problems.
Some participants have provided clarifications regarding the conditions for infinite solutions and the role of free variables. There is an acknowledgment of the need for careful consideration of the equations involved, particularly when certain values of "a" lead to different interpretations of the solution set. The discussion reflects a productive exchange of ideas without a clear consensus on all points.
Participants note the importance of understanding the implications of specific values of "a" on the solution set, particularly in relation to the definitions of basic and free variables. There is also mention of the lack of examples in the textbook that could aid in understanding these concepts.
LHC
List the conditions of "a" under which the system:
x + ay - z = 1
-x + (a-2) y + z = -1
2x + 2y (a-2) z = 1
i) Has no solutions:
ii) Has a unique solution:
iii) Has infinite solutions.
The attempt at a solution
Well, I changed the matrix into reduced row-echelon form and I found:
x = (a-1)/a
y = 0
z = -1/a
The textbook gives the following answers:
i) No solutions: a = 0 (which I understand...because otherwise there would be an undefined x and z)
ii) Unique solution: a not= 0 and a not= 1, then unique solution of:
x = (a-1)/a
y = 0
z = -1/a (same as above)
iii) Infinite solutions: if a = 1, then solutions of x = -t, y = t, z = -1
I don't understand the third case for infinite solutions. If a = 1, then wouldn't: x = 0, y = 0, z = -1?
Also, what is the general strategy for solving such problems? (Many of these types of problems are given in the section of the textbook that I'm going through, yet no example was ever given.) I mean, I understand how to get a unique solution, and how to get no solution, but I'm not sure how you would deduce the case for infinite solutions.
Thanks in advance!
A Linear System may have
1. A unique solution - the system is consistent
2. Infinite solutions - the system is consistent
3. No solutions - the system is inconsistent
To distinguish between a unique solution and infinite solutions:
If there are no basic variables, then the system has a unique solution.
If there are >= 1 free variables, the solutions has infinite solutions.
In
which are the basic, and free variables? Since there are at least 1 free variable, then the system has infinite solutions since t can be any number.
Sorry, this is a typo, it should be no free variables.
x + ay - z = 1
2x + 2y (a-2) z = 1
You mean 2x+ 2y+ (a-2)z= 1, don't you?
x = (a-1)/a
y = 0
z = -1/a
Be careful here. One of the equations reduces to 2(a-1)y= 0 which gives y= 0 provided a is not equal to 1. If a= 1, that equation is 0= 0 which is true no matter what y is. That's the case where there are an infinite number of solutions.
x = (a-1)/a
y = 0
Thanks in advance!
Thanks, konthelion and HallsofIvy, for your help. HallsofIvy, when you said "Be careful here. One of the equations reduces to 2(a-1)y= 0 which gives y= 0 provided a is not equal to 1. If a= 1, that equation is 0= 0 which is true no matter what y is. That's the case where there are an infinite number of solutions.", I looked back on the steps that I used to reduce the matrix and you're right. Thank you for clarifying this for me; now I understand the rest of these problems.
