Linear algebra: eigenvalue & character polynomials proof
The discussion revolves around proving that two matrices, A and B, defined by the relationship B = CAC-1, have the same characteristic polynomial. The context is linear algebra, specifically focusing on eigenvalues and characteristic polynomials without assuming any specific forms for the matrices.
  • Participants discuss the relationship between the determinants of the matrices and their characteristic polynomials, questioning how to show that the eigenvalues of both matrices are the same. There are attempts to manipulate the determinant expressions and apply the hint provided regarding the identity matrix.
Multiple participants are exploring different approaches to relate the characteristic polynomials of A and B. Some have made progress in understanding the determinant's role, while others are questioning the validity of their steps and the assumptions made. There is an ongoing examination of the implications of the hint given in the problem.
Participants note that they cannot assume A and B are triangular or diagonal matrices, which adds complexity to the problem. There is also mention of needing to prove not just the eigenvalues but also their multiplicities are the same.
ISuckAtMath
we are given B = CAC^-1
Prove that A and B have the same characteristic polynomial
given a hint: explain why ƛIn = CƛInC^-1
what I did was:
B = CAC^-1
BC = CA
Det(BC) = Det(CA)
Det(B) Det(C) = Det(C) Det(A)
Now they’re just numbers so I divide both sides by Det(C)
Det(B) = Det(A)
not I am stuck
The determinant is one term in the characteristic polynomial, but you need more than that to show the characteristic polynomials are the same.
The eigenvalues are the roots of the characteristic polynomial so you need to show that every eigenvalue of B is also eigenvalue of A, and vice versa.
If λ is an eigenvalue of B, then there is a vector x such that Bx = λx.
So you need to find a vector y such that Ay = λy.
You are only given one thing that connects A and B, so just plug and chug...
Suppose that C is an invertible matrix, and you are told that
B = CA(C^-1)
prove that A and B have exactly the same characteristic polynomial
do not assume A and B are triangular or diagonal matrices
given hint: explain why ƛIn = CƛIn(C^-1)
B = CA(C^-1)
BC = CA
Det(BC) = Det(CA)
now that they're just numbers, i divded both sides by Det(C)
Det(B) = Det(A)
i don't know what to do next
B = CA(C^-1)
B = CA(C^-1)
BC = CA
Det(BC) = Det(CA)
Det(B) = Det(A)
That's fine so far. But it doesn't help. What expression involving Det gives you the characteristic polynomial?
well i know det(ƛIn - A)= 0
thus giving the characteristic polynomial (ƛ-ƛ1)(ƛ-ƛ2)...(ƛ-ƛn)
do i set set det(ƛIn - A) = det(ƛIn - B)?
with the given vector v: Av = ƛv and Bv = ƛv
therefore Av = Bv?
therefore Av = Bv?
Ok, so the characteristic polynomial for B=CAC^(-1) is det(CAC^(-1)-lambda*I). Now pay attention to the hint.
therefore Av = Bv?
You would want to start with det(λI - A) and conclude that it equals det(λI-B), i.e. their characteristic polynomials are the same. Starting with det(λI-A), think about the relationship between A and B, then the hint, and recall that matrice have a distributive property which allows you to factor.
Note that proving that the eigenvalues are thesame for A and B isn't enough. You also need to prove that the multiplicities are the same.
is this correct?
B = CAC^(-1)
B-λIn = CAC^(-1) - λIn
using the hint: λIn = CλInC^(-1)
B-λIn = CAC(^-1) - CλInC^(-1)
B-λIn = C[ AC^(-1) - λInC^(-1) ] factored out C
B-λIn = CC^(-1)( A-λIn)
B-λIn = A-λIn, CC^(-1) cancel each other out
therefore det(B-λIn) = det(A-λIn)
so they're the same characteristic polynomial
what you want to do is compare:
det(xI - A) and det(xI - B) = det(xI - CAC-1).
here is a hint:
CIC-1 = I
ISuckAtMath said:
is this correct?
B = CAC^(-1)
No! The only way B-lambda*I=A-lambda*I is if A=B!. You can't prove that. You went wrong when you changed AC^(-1) into C^(-1)A in the third line. You can't do that. Matrices don't necessarily commute. Just factor the C^(-1) out on the right and the C on the left. Then take the det.
Oops. But that is easily fixed up. Just start the argument by saying
If λ is a diagonal matrix of all the eigenvalues of B, then there is a matrix x such that Bx = λx.
given a hint: explain why ƛIn = CƛInC^-1what I did was:
B = CAC^-1
BC = CA
Det(BC) = Det(CA)
Det(B) = Det(A)
not I am stuck
You are trying to prove that det(λI - B) = det(λI - A)
and there is basically no way to prove that B = A because they are really not equal to each other
You are given a hint that λI = CλIC-1
and B = CAC-1
then you substitute these two into det(λI - B)
you should be able to prove that det(λI - B) = det(λI - A)
*you will need to use the properties of determinants, and also matrix multiplication is associative, be careful when factoring any matrix out...
  • · Replies 25 ·
  • · Replies 18 ·
  • · Replies 19 ·
  • · Replies 24 ·
