Linear Algebra - independent vectors spanning R^3
The discussion focuses on the linear independence and spanning properties of the vectors {u-v, u+v} and {u+v, u-v} in the context of R3, where S={u,v,w} is a basis. It is established that {u+v, u-v} is linearly independent because the coefficients must equal zero, confirming that both vectors do not depend on each other. However, {u+v, u-v} cannot span R3 due to the limitation of having only two vectors, which restricts the dimension of the span to 2.
  • Understanding of linear independence in vector spaces
  • Knowledge of vector addition and scalar multiplication
  • Familiarity with the concept of span in linear algebra
  • Basic understanding of dimensions in R3
  • Study the concept of vector spaces and bases in linear algebra
  • Learn about the rank of matrices and its implications on linear transformations
  • Explore the properties of linear combinations and their applications
  • Investigate higher-dimensional vector spaces and their spanning sets
Students studying linear algebra, educators teaching vector spaces, and anyone seeking to deepen their understanding of linear independence and spanning in R3.
PirateFan308
Suppose that S={u,v,w} is a basis of R3.
a) Is {u-v,u+v} linearly independent? Why or why not?
b) Does {u+v,u-v} span R3? Why or why not?
na
a) Because we know that u,v,w are linearly independent and span R3, c1u+c2v+c3w = 0.
To test u+v, u-v, consider a(u+v)+b(u-v)=0. So, au+av+bu-bv=0, so u(a+b)+v(a-b)=0. Since u and v are linearly independent, a+b=0 and a-b=0. So 2b=0, so b=0, so a=0. So u+v, u-v are linearly independent.
b) Because there are only 2 vectors, u and v, the rank can only be 2, so it cannot span R3.
I'm pretty sure I got a) correct, but I'm not sure about b). Thanks!
na
Both a and b are right.
You got the first one right. The second one is essentially correct, but your terminology is off. When you say "rank", you're referring to a matrix or a linear transformation; here you have just two vectors. The span of {u+v, u-v} is a subspace of dimension 2.
