Linear algebra - Kernal and Range
The discussion revolves around proving that for a finite-dimensional vector space V and a linear transformation T: V -> V, there exists a natural number n such that the intersection of the kernel and range of T^n is the zero vector. Initial attempts to prove this for T were challenged by an example demonstrating that the intersection could contain non-zero vectors. The conversation highlights the importance of understanding the relationship between the dimensions of the kernel and range, particularly in the context of finite-dimensional spaces. A hint was provided regarding the dimensions of the subspaces formed by T, emphasizing the relationship between the kernel and range as n increases. Ultimately, the participants reached a resolution on the problem through collaboration and discussion.
sweetiepi
Let V be a finite-dimensional vector space and let T: V -> V be a linear transformation. Prove that there exists a natural number n so that
Ker(T^n) (intersection) Range(T^n) = {0}
Here, T^n represents the n-fold composition of T o T o ... o T
I can prove that Ker(T) (intersection) Range(T) = {0} by showing that if an element is in the intersection of the two spaces, it must be zero since would produce a linear combination of one basis equal to the other, and subtracting so they are on both sides gives a linear combination of both bases. But the sum of the spans of the two bases are linearly independent, so the coefficients must all be zero, and thus they can have only the zero vector in common. Now I'm unsure of how to relate this to T^n.
Your proof of ker(T) (intersect) range(T)={0} can't possibly be correct. Let T:R^2->R^2 be given by the matrix whose first row is [0,1] and whose second row is [0,0]. Then the column vector v=[1,0] is in ker(T) since T(v)=0 and v is in range(T) since T(u)=v, where u is the column vector [0,1]. Put that into your proof. Do you see what's wrong?
Sorry, in the problem where I showed that Range(T) (intersection) Ker(T) = {0} we were also given that Range(T) + Ker(T) = V. Does that make my explanation make more sense? I was trying not to have to replicate the whole proof but can see where that would have caused confusion. The proof has already been looked at by my professor so I am comfortable with it. The problem I am trying to prove now uses T^n and I don't know how to make that work.
If Range(T)+Ker(T)=V, then your proof probably makes perfect sense. But that's not generally true for any T. I just gave you an example where it's not true. But it's still true that Ker(T^n) (intersection) Range(T^n) = {0} for some n for ANY T, if V is finite dimensional. Range(T)+Ker(T)=V is just a special case. That's the n=1 case, I gave you an example of the n=2 case. Don't confuse that with dim(range(T))+dim(ker(T))=dim(V) which is always true.
Ok, here's a hint. How does dim(T(range(T)+ker(T))) compare with dim(range(T)+ker(T))?
Well, if you take T(range(T) + ker(T)) because T is linear you can compute T(range(T)) + T(ker(T)) and because the kernel of T maps to the zero vector you are left with T(range(T)) so the dim(T(range(T))) would be the number of vectors in the basis of range(T)? Whereas the dim(range(T)+ker(T)) would be the dimension of the number of vectors in the basis for the range plus the number of vectors in the kernel? I'm not really sure if that is right...
And I'm not sure what my 'hint' is exactly supposed do. It seemed to make sense at the time. Try this. You know range(T^(n+1)) is a subspace of range(T^n), right? And ker(T^n) is a subspace of ker(T^(n+1)). Given that V is finite dimensional, what can you say about the sequences of subspaces range(T^n) and ker(T^n)?
I actually worked on this problem with a friend earlier today and we got it all figured out. Thank you for your help though!
  • · Replies 24 ·
