Linear Algebra (Linearly Dependent)
6 replies · 3K views
tweety24
a = [2, 2, 2]
b = [3, 0, 1]
Find all vectors c so that the vectors a, b, c are linearly dependent.
(a x b) . c
( . = dot product)...is this how I'm supposed to get started?
linearly dependent would mean make it equal to zero right?
when i use the triple product i get 2c1 + 4c2 - 6c3 = 0
i don't know where to go from there
That's one way to express it. The set of all vectors c=[c1,c2,c3] such that 2c1 + 4c2 - 6c3 = 0. If you want to go one step further you solve your equation for, say c1. Then you could express c in terms of just the two parameters c2 and c3. If you think about it a little bit, you could probably find a way to express c in terms of two parameters without even going through the triple product.
Thanks =)
So if I was going to solve for c1 would it be something like
c1 = -2c3 + 3c3
okay sweet, thank you! =)
Not really, I'm not sure how it would work the other way without the triple product.
Dick said:
How about c=s*[2, 2, 2]+t*[3, 0, 1]?
What Dick is suggesting here is the simplest, most straightforward approach. If you want to find all vectors c so that {a, b, c} is a linearly dependent set, and you can tell by inspection that a and b are linearly independent, then c must be a linear combination of a and b. This is exactly what Dick's equation represents.
