Linear algebra, orthogonal matrix proof
14 replies · 11K views
fluidistic
Demonstrate that the following propositions hold if A is an nxn real and orthogonal matrix:
1)If [itex]\lambda[/itex] is a real eigenvalue of A then [itex]\lambda =1[/itex] or [itex]-1[/itex].
2)If [itex]\lambda[/itex] is a complex eigenvalue of A, the conjugate of [itex]\lambda[/itex] is also an eigenvalue of A.
For part 1) I used the fact that A orthogonal implies [itex]A^{-1}=A^T[/itex]. Also that [itex]\det A = \frac{1}{det A^{-1}}[/itex], and that [itex]\det A = \det A^T[/itex]. I didn't demonstrate the 2 latter relations, I just assumed them to be true.
I've done part 1), I'm just lazy to write down the detailed proof. I made use of the relevant equations I've written.
However for 2) I'm totally stuck at even planting the problem. I started by writing [itex]\lambda = a+ib[/itex] and its conjugate [itex]\overline \lambda = a-ib[/itex] but this lead me nowhere and stuck immediately.
I think I've read in wikipedia yesterday that the eigenvalues of an orthogonal matrices all have modulus 1. If I remember well, A is diagonalizable and put under this form I should "see that all eigenvalues of A have modulus 1".
If this is the simpler approach, please let me know. I could demonstrate that A is diagonalizable first and then try to go further.
In the demonstration in 1), at one point I reach the fact that [itex]\lambda A ^T =I=\lambda A[/itex]. So clearly A is... diagonal (this is not necessarily true so this looks like a mistake... damn it.)
My proof for 1):
I must show that [itex]Ax=\lambda x \Rightarrow \lambda = \pm 1 \forall x \in \mathbb{R}^n[/itex].
I multiply both sides by the inverse of A: [itex]A^{-1}Ax= A ^{-1} \lambda x \Rightarrow x= \lambda A^{-1}x[/itex].
[itex]\Rightarrow \lambda A^{-1}=I \Rightarrow \det A^{-1}=\frac{1}{\lambda }[/itex]. But we also have that [itex]\lambda A^T=I[/itex] because A is orthogonal. Since A is a square matrix, [itex]\det A =\det A^T[/itex] too. Thus we have that [itex]\det A =\det A^T \Rightarrow \det (\lambda A ^T )=1 \Rightarrow \det (\lambda A )=1 \Rightarrow \det A = \frac{1}{\lambda}[/itex].
[itex]\Rightarrow \det A = \det A^{-1}[/itex]. But for any invertible matrix A, [itex]\det A = \frac{1}{\det A ^{-1}}[/itex].
So that if [itex]a = \det A[/itex], then [itex]a= \frac{1}{a} \Rightarrow a^2=1 \Rightarrow a = \pm 1[/itex]. And since [itex]\lambda = \frac{1}{\det A}[/itex], I reach [itex]\lambda = \pm 1[/itex].
Any tip/help will be appreciated. Thanks.
Hi fluidistic! :smile:
Let's start with your proof for 1).
You infer [itex]x= \lambda A^{-1}x \Rightarrow \lambda A^{-1} = I[/itex].
I'm afraid this is not generally true.
The implication would be that A is a diagonal matrix, which it obviously doesn't have to be.
As a hint for 1): what is |Ax|?
As a hint for 2): suppose [itex]Av = \lambda v[/itex], what is the conjugate of (Av)?
[itex]x= \lambda A^{-1}x \Rightarrow \lambda A^{-1}=I[/itex].
[itex]\lambda A^{-1}[/itex] mapping all eigenvectors of A to themselves does not imply [itex]\lambda A^{-1} = I.[/itex]
Hi and thanks to both of you guys.
Oh I see. I really wasn't aware of this so I'm quite surprised. So basically I have a vector x in R^n and it's worth a matrix times exactly the same vector x. If this matrix isn't necessarily the identity, can you give me an example of such a matrix? Say a 2x2 matrix. I just tried myself to find such an example and failed (probably due to some algebra mistake, I don't see what I did wrong).
For 1), is it [itex]|\lambda x|[/itex]?
For 2), here I'm confused. A is a real matrix, I think it means that all his entries are real. I realize that it can have complex eigenvalues though. Also, I thought that x was in R^n. It seems like the entries of x can be in C^n? Because otherwise I don't see how to reach [itex]\lambda x[/itex] with [itex]\lambda[/itex] being complex valued.
I think I need to make a nap, I'm extremely tired so I feel I'm not thinking as hard as I should right now; unlike when I started the problem.
Thanks for any further push.
Try [itex]\begin{pmatrix}0 & 1 \\ 1 & 0\end{pmatrix}[/itex].
Noooo, I didn't say x was an eigenvector. :rolleyes:
Try to use the properties of an orthogonal matrix.
Your problem doesn't say that x has to be real.
And anyway, if lambda is complex, the corresponding eigenvector has to be complex too (can you proof that?)
As you can see I avoided using x here.
I'm thinking of x as any real valued vector, and I'm thinking of v as a specific eigenvector, which may be complex valued.
Such a vector is called an eigenvector of the matrix. In your attempt, I noticed you said Ax=λx for all x in Rn, but that's not correct. It only holds for certain vectors, the eigenvectors of A.
ILS wants you to use the definition of the norm of a vector and apply it to the vector Ax.
Well I reach [itex]\begin {bmatrix} x_1 \\ x_2 \end{bmatrix}=\begin {bmatrix} x_2 \\ x_1 \end{bmatrix}[/itex]. So unless I'm mistaken this matrix doesn't work.
Ah I see! If I remember well something I've read somewhere I don't remember, orthogonal matrices preserve lengths so that |Ax|=|x|.
I think I can prove it. I was having problems because I assumed x was in R^n.
If lambda is complex, A has real entries and x also has real entries then there's no way that a multiplication/sum of real numbers give a complex number. So that x has to be complex valued. (I'm having in mind the picture Ax=lambda x.)
You mean x any complex and real valued?
Oh thanks for pointing this out. I had the doubt for a moment and made an error with this. I assumed for some reason that having an infinity of eigenvectors couldn't be possible while of course it is. Only the direction matters, versus their lengths.
[itex]||Ax||=\sqrt {<Ax,Ax>}[/itex] where <,> denotes the inner product. Or do you mean a specific norm?
But it will work for specific vectors
\begin{align*}
\begin{pmatrix} 0 & 1 \\ 1 & 0 \end{pmatrix}\begin{pmatrix}1 \\ 1\end{pmatrix} &= (1)\begin{pmatrix} 1 \\ 1\end{pmatrix} \\
\begin{pmatrix} 0 & 1 \\ 1 & 0 \end{pmatrix}\begin{pmatrix}1 \\ -1\end{pmatrix} &= (-1)\begin{pmatrix} 1 \\ -1\end{pmatrix}
\end{align*}
If you demand that every vector x in Rn satisfies Ax=λx, then you're right that A is a multiple of the identity matrix.
I'm not sure what you're saying here. :)
Now using the fact that A is orthogonal, you can show |Ax|=|x|, which is what I think ILS was trying to get you to see. Now suppose x is an eigenvector of A.
I see vela has already given the answers that you need to move on.
I'll just give a couple of additional comments. :smile:
Yep! That's it. :)
Yep!
Whatever.
Yes, I meant this one.
When not specified, this one is always meant.
Thanks once again guys!
Well I'm stuck at showing that [itex]||Ax||=||x||[/itex]. I know I have to use the fact that [itex]||Ax||=\sqrt {<Ax,Ax>}[/itex] and that A is orthogonal ([itex]A^T=A^{-1}[/itex]).
I'm thinking about using some properties of the inner product but I can't find any interesting for this case.
Ah, well, I didn't really intend for you to proof it.
As far as I'm concerned it's simply a property of an orthogonal matrix.
But if you want to proof it, you can use: ||Ax||2 = (Ax)T(Ax).
Do you know how to simplify that?
Yeah I'd rather prove it, otherwise I feel like I'm assuming what I want to prove. :)
Oh bright idea. I think I do know how to simplify it. [itex](Ax)^T(Ax)=x^TA^TAx=x^Tx=||x||^2[/itex]. Since [itex]||v|| \geq 0[/itex] for any vector v, we reach [itex]|Ax|=|x|[/itex]. I'm going to think on how to proceed further. Will post here as soon as I get results or get stuck.
What I get: Let x be an eigenvector associated with the eigenvalue lambda. [itex]Ax= \lambda x \Rightarrow |Ax|= |\lambda x | =|x| =|\lambda || x|\Rightarrow |\lambda |=1[/itex]. Thus if [itex]\lambda \in \mathbb{R}[/itex] as stated, then [itex]\lambda = 1[/itex] or [itex]-1[/itex].
Good! :smile:
(Although in a proper proof, you should mention that you are using the property of an orthogonal matrix that the norm of a vector is invariant.
Of course, I already know in this case. :wink:)
As an afterthought, you may want to distinguish the vector norm ||*|| from the absolute value |*| (when applied to lambda) here.
Thanks once again. I've been so busy I can't even believe it's been 3 (oh 4 this minute) days I've last written in this post.
Yeah on my draft I've redone the exercise and made use of the norm of lambda*x and modulus of lambda, I think I did it well.
Thanks for pointing this out though. :)
