Linear Algebra, Orthonormal question
16 replies · 4K views
wtmoore
I have this question that I am trying to figure out about orthonormality,I have tried to take a picture of it and put it on here but I can't figure out the url. Anyway I will try and write it out.
Show that the vector {sin(x),cos(x)} is a basis for the vector space defined by:
V={asin(x) + bcos(x) l a,b ε ℝ, 0≤ x ≤ pi} using the inner product :
<f,g>=∫(0 to pi)fgdx, fgεV
and determine an orthonormal basis.
I found the integral of sin(x)cos(x)dx between 0 and pi to be 0.
This make it orthonormal right as it's the same as the dot product.
Now I think I have to find out whether <f,f> is = 1 (of unit length)
so I did integral of sin^2(x)dx between 0 and pi but found pi/2. I also found the same for cos^2(x).
Does this mean they are not orthonormal? I don't know if it makes a difference that <f,f>=<g,g>.
Thanks
Thanks
Correct, sin(x) and cos(x) are orthogonal [their inner product with each other is zero] but not orthonormal [their norms are not 1]. There's a very simple modification you can make to sin(x) and cos(x) which will make them orthonormal. Do you see what it is?
What I find helps when you're first working with the notion of 'functions as vectors' is to look back to your basic 3-vectors and think about what these properties mean for them.
Orthogonal 3-vectors have a.b = 0, orthogonal functions have f.g = 0
Normalised vectors have a.a = 1, normalised functions have f.f = 1
Think about how you normalise 3-vectors. Think about how you orthogonalise 3-vectors.
Here's another little problem you can do which is kinda fun, build up a set of orthogonal polynomials using the gram-schmidt process (these polynomials are the legendre polynomials)
I think so, I sort of spotted it but wasn't sure. Do I define some sort of new function, let's say h(x), where h(x) = (π^-0.5)sin(x)? Then <h,h> = 1? This is normalization right?
jbunniii said:
P.S. It's clear that V is spanned by sin(x) and cos(x), but the definition of a basis also requires that these functions must be linearly independent. Did you show that?
I can explain it but don't know how to write this in a neat way. For example if I plug in values for x between 0 and π, let's take 0, then I know that this makes the sin term 0 and cos positive, and if we take pi/2 for example then it's the other way around. So for whatever value is taken between 0 and pi, one of them is a positive and one is 0, therefore a=b=0.
I however don't know how to express this in proper notation.
Right idea, but I think your scale factor is off. If your original function had <f,f> = pi/2, then you would want to define h = sqrt(2/pi)*f.
I mean <f,f> = pi sorry, then h=pi^(-0.5)*f would work?
Yes, you have the right idea. You want to show that if
a cos(x) + b sin(x) = 0 for all x,
then a and b must be 0.
So pick some specific values of x that are easy to work with. I suggest x = 0 and x = pi/2.
But is <f,f> = pi?
Isn't it
[tex]\int_{0}^{\pi} sin^2(x) dx[/tex]?
This should work out to pi/2, not pi. And similarly for cos(x).
jbunniii said:
But is <f,f> = pi?
Isn't it
Yeh originally I did it from 0 to pi but when I double checked for some reason I made a mistake and did it from -pi to pi.
Ok so I just need (pi/2)^(-1)?
Yeh I tried these,
acos(0)+bsin(0)=0
Then a must be 0.
acos(pi/2)+bsin(pi/2)=0
then b must be 0.
Is it enough to write this, or is there some sort of other form I can generalize it for?
The square root of that.
wtmoore said:
Yeh I tried these,
acos(0)+bsin(0)=0
Then a must be 0.
then b must be 0.
That's enough. If the linear combination equals zero, it has to equal zero at every value of x, including the two you chose (0 and pi/2). Those two alone are enough to imply that a = b = 0. You could have picked almost any pair of values of x, as long as they resulted in a solvable system of two equations with two unknowns. 0 and pi/2 just make the math easier.
Thanks jbunniii,
I understand all of it, and have managed to complete 2 similar questions now.
My only question is, why is it the square root? Surely if <f,f> = pi/2 then we need 2/pi to make this 1?
wtmoore said:
Thanks jbunniii,
No, suppose you set [itex]h = \alpha f[/itex]. Then
[tex]<h,h> = <\alpha f, \alpha f> = \alpha^2 <f,f>[/tex]
You want this equal to 1, so
[tex]\alpha^2 = 1/<f,f>[/tex]
and hence
[tex]\alpha = \sqrt{1/<f,f>}[/tex]
Yeh I was thinking just at the end not the fact that they are going to multiply each other. Thanks for all your help Jbunnii
