Linear Algebra, Orthonormal question
The discussion revolves around the concept of orthonormality in the context of linear algebra, specifically focusing on the vector space defined by functions of the form {asin(x) + bcos(x)} for real numbers a and b, within the interval [0, π]. The original poster is tasked with showing that the vector set {sin(x), cos(x)} forms a basis for this space using a defined inner product.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • The original poster attempts to determine the orthonormality of the functions sin(x) and cos(x) by calculating their inner products and norms. They question whether the results imply orthonormality and express uncertainty about the implications of their findings.
  • Some participants clarify that while sin(x) and cos(x) are orthogonal, they are not orthonormal due to their norms not being equal to one. Suggestions are made regarding how to modify these functions to achieve orthonormality.
  • There are discussions about the linear independence of the functions and how to demonstrate this property using specific values of x.
The discussion is active, with participants providing insights and guidance on the properties of orthogonal functions and the steps needed to establish orthonormality. There is a recognition of the need to clarify definitions and properties related to the basis of the vector space, and participants are exploring various approaches to normalization.
Participants are working under the constraints of homework guidelines, which may limit the extent of direct assistance. There is an ongoing exploration of the definitions and properties of orthonormality and linear independence, with some confusion regarding the calculations of inner products and norms.
wtmoore
I have this question that I am trying to figure out about orthonormality,I have tried to take a picture of it and put it on here but I can't figure out the url. Anyway I will try and write it out.
Show that the vector {sin(x),cos(x)} is a basis for the vector space defined by:
V={asin(x) + bcos(x) l a,b ε ℝ, 0≤ x ≤ pi} using the inner product :
<f,g>=∫(0 to pi)fgdx, fgεV
and determine an orthonormal basis.
I found the integral of sin(x)cos(x)dx between 0 and pi to be 0.
This make it orthonormal right as it's the same as the dot product.
Now I think I have to find out whether <f,f> is = 1 (of unit length)
so I did integral of sin^2(x)dx between 0 and pi but found pi/2. I also found the same for cos^2(x).
Does this mean they are not orthonormal? I don't know if it makes a difference that <f,f>=<g,g>.
Thanks
Thanks
Correct, sin(x) and cos(x) are orthogonal [their inner product with each other is zero] but not orthonormal [their norms are not 1]. There's a very simple modification you can make to sin(x) and cos(x) which will make them orthonormal. Do you see what it is?
P.S. It's clear that V is spanned by sin(x) and cos(x), but the definition of a basis also requires that these functions must be linearly independent. Did you show that?
What I find helps when you're first working with the notion of 'functions as vectors' is to look back to your basic 3-vectors and think about what these properties mean for them.
Orthogonal 3-vectors have a.b = 0, orthogonal functions have f.g = 0
Normalised vectors have a.a = 1, normalised functions have f.f = 1
Think about how you normalise 3-vectors. Think about how you orthogonalise 3-vectors.
Here's another little problem you can do which is kinda fun, build up a set of orthogonal polynomials using the gram-schmidt process (these polynomials are the legendre polynomials)
I think so, I sort of spotted it but wasn't sure. Do I define some sort of new function, let's say h(x), where h(x) = (π^-0.5)sin(x)? Then <h,h> = 1? This is normalization right?
I can explain it but don't know how to write this in a neat way. For example if I plug in values for x between 0 and π, let's take 0, then I know that this makes the sin term 0 and cos positive, and if we take pi/2 for example then it's the other way around. So for whatever value is taken between 0 and pi, one of them is a positive and one is 0, therefore a=b=0.
I however don't know how to express this in proper notation.
Right idea, but I think your scale factor is off. If your original function had <f,f> = pi/2, then you would want to define h = sqrt(2/pi)*f.
I mean <f,f> = pi sorry, then h=pi^(-0.5)*f would work?
Yes, you have the right idea. You want to show that if
a cos(x) + b sin(x) = 0 for all x,
then a and b must be 0.
So pick some specific values of x that are easy to work with. I suggest x = 0 and x = pi/2.
But is <f,f> = pi?
Isn't it
[tex]\int_{0}^{\pi} sin^2(x) dx[/tex]?
This should work out to pi/2, not pi. And similarly for cos(x).
jbunniii said:
But is <f,f> = pi?
Isn't it
Yeh originally I did it from 0 to pi but when I double checked for some reason I made a mistake and did it from -pi to pi.
Ok so I just need (pi/2)^(-1)?
Yeh I tried these,
acos(0)+bsin(0)=0
Then a must be 0.
acos(pi/2)+bsin(pi/2)=0
then b must be 0.
Is it enough to write this, or is there some sort of other form I can generalize it for?
The square root of that.
wtmoore said:
Yeh I tried these,
acos(0)+bsin(0)=0
Then a must be 0.
then b must be 0.
That's enough. If the linear combination equals zero, it has to equal zero at every value of x, including the two you chose (0 and pi/2). Those two alone are enough to imply that a = b = 0. You could have picked almost any pair of values of x, as long as they resulted in a solvable system of two equations with two unknowns. 0 and pi/2 just make the math easier.
Thanks jbunniii,
I understand all of it, and have managed to complete 2 similar questions now.
My only question is, why is it the square root? Surely if <f,f> = pi/2 then we need 2/pi to make this 1?
wtmoore said:
Thanks jbunniii,
No, suppose you set [itex]h = \alpha f[/itex]. Then
[tex]<h,h> = <\alpha f, \alpha f> = \alpha^2 <f,f>[/tex]
You want this equal to 1, so
[tex]\alpha^2 = 1/<f,f>[/tex]
and hence
[tex]\alpha = \sqrt{1/<f,f>}[/tex]
Yeh I was thinking just at the end not the fact that they are going to multiply each other. Thanks for all your help Jbunnii
  • · Replies 18 ·
