Linear Algebra Proof using Inverses
The discussion revolves around proving that if ABC = I for square matrices A, B, and C, then B is invertible and B−1 = CA. The initial attempt at a solution involved manipulating the equation but faced challenges regarding the justification of steps, particularly concerning the invertibility of B. Participants emphasized that while the steps may be mathematically valid, additional reasoning is necessary to support claims about the invertibility of matrices. The consensus is that a more detailed explanation of each step is required to meet academic standards. Clear justification for each assertion is crucial in formal proofs.
B18
Prove that if A, B, and C are square matrices and ABC = I, then B is invertible and B−1 = CA.
I think I have this figured out, just checking it. Heres what I got:
ABC=I
(ABC)B-1=IB-1
(B*B-1)AC=IB-1
I*AC=IB-1 Cancel I using left hand cancellation property
AC=B-1
Thus B-1=CA
Is every thing I've done here mathematically correct?
ABC=I
(ABC)B-1=IB-1
How do you know ##B## has an inverse to use? You are trying to prove that.
(B*B-1)AC=IB-1
And, even if you did, how did you get that step? Matrix multiplication isn't commutative.
Ok, yes I see what you're saying. I can't do the steps I did there. I know that B has to have an inverse because A,B, and Care square matrices and their product is the identity matrix.
Is this a correct path to go down on this proof?
We have ABC=I
(AB)C=I. Since (AB)C=I we know that (AB) and C are both invertible. Also this tells us that C=(AB)-1, and (AB)=C-1
You can also reorder the multiplication using
CABC = CI = C =IC
Implies CAB = I.
Same logic as in your last post should bring you to the solution you are looking for.
How does this look:
We have ABC=I
C(ABC)=CI
CABC=C
(CABC)A=CA
(CAB)CA=CA This implies that CAB=I
CA(BCA)=CA This implies that BCA=I
CAB=BCA
(CA)B=B(CA) Then B must be invertible
Therefore BCA=I
CA=B-1
Looks good to me. You hit all the important points.
I think you need to flesh out your argument with a few more details. Your steps may be correct, but if this is a homework problem you need to fill in some reasons.
B18 said:
How does this look:
We have ABC=I
C(ABC)=CI
CABC=C
(CABC)A=CA
Why do those imply those?
CAB=BCA
Why must B be invertible? That statement by itself doesn't imply it.
Therefore BCA=I
Why the "therefore" now? Didn't you already have BCA=I above?
CA=B-1
Like I said above, your statements may be true, but your teacher is going to want to know if you know why they are true.
  • · Replies 25 ·
  • · Replies 24 ·
