Proving Linear Independence and Spanning in Vector Spaces
The discussion focuses on proving that a maximal linearly independent sequence in a vector space V spans V and serves as a basis. It establishes that if a sequence (v1, ..., vk) is maximal and linearly independent, adding any additional vector creates a dependency, indicating that the new vector can be expressed as a linear combination of the existing vectors. This confirms that the sequence spans V, fulfilling the definition of a basis. The conversation emphasizes the importance of structuring the proof correctly to avoid circular reasoning.
  • Understanding of vector spaces and their properties
  • Knowledge of linear independence and spanning sets
  • Familiarity with linear combinations of vectors
  • Basic proof techniques in linear algebra
  • Study the concept of basis in vector spaces
  • Learn about the Rank-Nullity Theorem in linear algebra
  • Explore examples of maximal linearly independent sets
  • Investigate the implications of linear dependence in vector spaces
Students and educators in linear algebra, mathematicians focusing on vector space theory, and anyone interested in understanding the foundational concepts of linear independence and spanning sets.
Danielm
Prove the following: Let V be a vector space and assume there is an integer n such that if (v1, . . . , vk) is a linearly independent sequence from V then k ≤ n. Prove is (v1, . . . , vk) is a maximal linearly independent sequence from V then (v1, . . . , vk) spans V and is therefore a basis.
If v_1,...,v_k$spans V then all vectors in V are generated by some linear combination of v_1,...,v_k. It's clearly seen that we can generate any vector in the sequence by setting the constant of the desired vector to 1 and the others to 0. Hence the sequence is maximal linearly independent, adding another vector will provoke a dependency. The dependency didn't exist before the new vector was added. This implies that the added vector can be written as a linear combination of the other vectors. If we do this for every remaining vector in V, then all vectors can be written as a linear combination of the given sequence and therefore it spans V. The sequence is linearly independent and it spans V, so it's a basis.
is that correct?
You are asked to prove it spans V. Starting with "if v1..vk spans V" is not helpful.
So if I delete the first sentence, it would look better? because clearly that's what I want to prove.
You'll need to delete all that followed from that, i.e. the first two and a half lines. So it now starts
That seems to work.
  • · Replies 23 ·
