How Do You Solve a 7th Degree Polynomial Interpolation by Hand for Given Points?
The discussion centers on solving a 7th degree polynomial interpolation by hand for a given set of eight points. Participants highlight the challenge of deriving an exact polynomial function without a calculator, emphasizing the necessity of using linear algebra techniques. The problem can be formulated in matrix form as Ax = b, where A is an 8x8 matrix representing the coefficients of the polynomial. Techniques such as Gaussian elimination are recommended for solving the system of equations, although the complexity of manual calculations is acknowledged.
  • Understanding of polynomial interpolation
  • Familiarity with linear algebra concepts, specifically matrix representation
  • Knowledge of Gaussian elimination method
  • Ability to perform manual calculations with precision
  • Study polynomial interpolation methods, particularly Lagrange and Newton forms
  • Learn about matrix operations and their applications in solving linear equations
  • Practice Gaussian elimination with various matrix sizes
  • Explore numerical methods for polynomial fitting, including least squares approximation
Students in linear algebra courses, mathematicians, and anyone interested in polynomial interpolation techniques and manual computation methods.
adamp1988
Given the following points, generate the function of the curve in form of a 7th degree polynomial.
(1.301, -0.788)
(1.477, -0.454)
(1.602, -0.194)
(1.700, 0)
(1.778, 0.158)
(1.845, 0.288)
(1.903, 0.410)
(1.954, 0.500)
Furthermore, the solution has to be done without a calculator (during exams).
Don't know of any
I tried using the interpolation polynomial, however the graph equation has to be an exact match because I am required to calculate numerous addition details from the equation.
Thanks!
haha that function doesn't sound very linear to me. I have no idea how to do that, but i would try using the method of least squares.
A seventh-degree polynomial isn't linear...
The question seems a bit odd considering the points are given with three digit accuracy, a 7th degree polynomial is involved, and you are asked to solve it w/o a calculator.
Since this appears to be from a linear algebra class and you have 8 data points to represent a 7th degree polynomial (with 8 unknowns), the problem can be represented in matrix form Ax = b where A is a 8 x 8 matrix, x is the unknown vector of the polynomial coefficients, and it can solved with techniques learned in linear algebra (e.g. Gauss elimination). But, the solution by hand, even algebraically, would be a real bear, much less tying to do the computations with points to 3 digit accuracy.
I think you need clarification as to what is being asked and how it relates to linear algebra.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
9K
