Linear Approximation: Approximating \sqrt{4.1}-\sqrt{3.9}
12 replies · 5K views
antinerd
OK, I'm doing this linear approximation problem:
Approximate [tex]\sqrt{4.1} - \sqrt{3.9}[/tex]
f(a + h) ~ f(a) + hf`(a)
This is what I have done so far:
I approximated each square root separately...
4.1 = 4 + h
h = .1
f(x) = [tex]\sqrt{x}[/tex]
f`(x) = [tex]1/(2\sqrt{x}[/tex]
then I got:
[tex]\sqrt{x+h} ~ \sqrt{x} + h/(2\sqrt{x})[/tex]
so that the approximation of [tex]\sqrt{4.1}[/tex] is 2 + (.1/4)
I did the same thing for [tex]\sqrt{3.9}[/tex] and got
2 - (.1/4)
Then I just took them and subtracted
2 + (.1/4) - 2 + (.1/4)
and got .2/4 as the approximation. It seems like it's erroneous. Could someone help me out with setting up this problem if I did it wrong?
All you steps are right. Why do you think it is erroneous?
It seems to me that it is a large margin of error, I was just wondering why this is so.
Or maybe it's not too large, I'm not sure...
everything looks right to me.
check your calculator and calculate [tex]\sqrt{4.1} - \sqrt{3.9}[/tex]
it's very close to 0.2/4 = 0.05
It's an approximation. Without a calculator, it's not an easy task for many to calculate the square root of an arbitrary number, unless it's a "nice" number like a perfect square. In those cases, you can use this method to approximate square roots to find a number reasonably close to the right one.
So let's say I was doing something like e^(-0.1) - ln (1.1)
I can just go about doing it thus:
h = -0.1
so that:
-0.1 = 0 + h and 1.1 = 1 - h
for the first term:
f(x) = e^(x)
f`(x) = e^(x)
but then how do I go about it from there...
Could someone help me setup the problem?
I guess this would work, wouldn't it:
e^(0) - h/(e^(0))
1 - 0.1 = 0.9
Which seems reasonable...
And then for the ln(1.1) it would be
f(x) = ln(x)
f`(x) = 1/x
ln(1) - h/x
which would give me
0 - (-0.1/1)
= 0.1
That doesn't make any sense...
What'd I do wrong.
What's the problem?
Integral said:
What's the problem?
EDIT:
Should I use -0.1 for h or can i use 0.1...
When I do:
e^0 - (h / e^0)
= 1 + (0.1/1)
= 1.1
It should be 0.9 ...
I have the correct approximation for -ln(1.1) = 0.1
but I made a mistake
e^(0) - h/(e^(0))
1 - 0.1 = 0.9
Shouldn't it be 1 PLUS 0.1 to give me 1.1? Cuz h = NEGATIVE 0.1
What's wrong here?
Holy crap man, nevermind. I've been up for like 3 days straight so I'm buggin' out.
Thanks for your insight, guys :)
h = -0.1
so that:
for the first term:
f(x) = e^(x)
f`(x) = e^(x)
e^(0) - h/(e^(0))
1 - 0.1 = 0.9
Although the numbers come out right, I'm wondering why you are dividing by e^(0) instead of multiplying by e^(0)
I would advise that you approximate each term separately so that you don't get confused with the signs... Also, define h consistently...
so I'd do this:
let h = [tex]x_{actual}-x_{approximate}[/tex]
So if I'm approximating e^(-0.1) by e^0...
h = -0.1 - 0 = -0.1
And then use this exact formula where a refers to the approximate x value:
f(a + h) ~ f(a) + hf`(a) (don't switch from h to -h or anything like that... be consistent)
So: f(0 + (-0.1)) ~ f(0) + (-0.1)f'(0)
ie: e^(0 + (-0.1)) ~ e^(0) + (-0.1)(e^(0)) = 0.9
So e^(-0.1) ~ 0.9
Now approximate ln(1.1) as a separate problem, defining h again...
It is important to be consistent... worry about signs at the end...
